aw man thats horrible at lest you got off easier then it could have been, those defects are easy fix's though right? slap on some stockies. make a cold air box (i have the stock box and snorkle i can send up to you if you want) and just jack up the coils?
best of luck with it mate!
Yea definitely could have been worse, just a pain in the ass. The defect notice requires a full inspection/blueslip to be cleared though, so it depends how much of a c*nt the local guys want to be. I just went and saw one guy during my lunch break (everyone has been recommending him to me as being the more leanient of the local guys) and he said make the exhaust quieter, stock wheels, stock air box (I still have my stock one luckily, but thanks for the offer :D ), and raise the back of the car up a little bit and it should be ok. He didn't really look at the car though so I'm a little skeptical he will change his mind tomorrow which I was luckily able to book the car in to be checked on.
Well, yesterday I raised the car suspension and had it realigned. All was good in the world. Until I decided to test the newly acquired launch control with semi's on haha. Now I'm on the hunt for replacement driveshafts. Better now then at the supersprint or hill climbs I've entered next month lol.
Anyway, for your personal entertainments, here is a video of bangs and flames.
Edited by timmy_89
Well I managed to source some second hand drive shafts from a fellow SAU member nice and cheap, and then it turned out I had a friend who would be driving within about 5kms of where the guy lived, so he picked them up for me the following day, which meant I had my replacement driveshafts before the weekend.
The process of changing the driveshaft over was actually easier then I thought it would be. Just unbolt the upper arms from the hub and the 5 bolts on the diff end and with a bit of maneuvering I was able to slide it out.
After bolting everything back up it was time to have a couple of beers and open up the boot on the old shaft. Whilst removing the from the car, it felt pretty obvious that the CV was shattered.
I figure it can be repaired with a bit of superglue right?
  • Like 2
Nice build mate. How much did the gear box shipping cost? I had a look at RHDJapan website and the box itself is around 1.6k aussie. Did they charge you much for shipping?
Cheers
Amir
Cheers.
At the time it cost me ~$1800 for the gearbox and ~$400 for shipping.
  • 1 month later...
So yesterday I entered myself into the supersprint at Mount Panorama held by the Bathurst Light Car Club, the first supersprint that had been ok'd by council in the last 3 years.
The day started out beautiful, but made a drastic change into a downpour of rain after only the first couple of runs which meant I really only got 1 sighting run and 1 "fast" lap of 52.47 seconds before the track was wet.
In the end they had to call the day short (still managed a few wet runs). Definitely something I'll be aiming to get to again to improve on times.
Vid of my last run in the wet, which as you can see was slippery as hell!!
EDIT: Second YouTube link not working so posting in next comment :)
Edited by timmy_89
  • Like 1
    • I had absolutely no symptoms whatsoever that anything was wrong.... I'm very happy it was all spotto'd and re-bled and re-torqued and aligned though. Will be picking it up tomorrow and undoubtedly be like "Oh, that clunk is gone" "Oh, the car really wants to drive straight" "Oh, that pedal feels better" "Oh, it feels like I've gained 25hp" "Oh, the handbrake works now" It should have been a sign that the new Project Mu shoes had 3mm of pad depth on them out of the box, and the OEM ones from 25 years ago that we took out also had 3mm of pad depth, implying the issue was not, and never was the shoes, but we put that down to it not being adjusted correctly. It wasn't, but it wasn't even adjustable at all given one side was boned and the T Junction of the cables was on a 45 degree angle, the non-working side being the one on the massive angle. Obviously when I had adjusted it and reset it and re-tensioned it I had either got it stuck or something along those lines. Oh well. Live and learn and absolutely could have been catastrophically worse so I'm rationalizing it as a win, kinda. I also got the chance to measure the distance between rear rim and the suspension arm/shocks and found a 30mm rubber block only just doesn't fit there. Which is great to know before ordering wheels, when I assumed 30mm was easy. The man with the Porsche adapters has rims that use 23.9mm of that space, so it's safe to assume I have between 23.9 and 29.9mm of space there to play with on the inside. The wheels looked pretty stupidly pokey with the 20mm spacers on the rear, only for me to find that the studs come out another 12mm and the wheel doesn't actually sit flush with the hub because you're supposed to cut your original studs. The wheels do have cutouts that kinda accomodate it, but not fully. So my 20mm spacer was anywhere between 25mm and 35mm. ~25mm and send it will determine on where the wheels sit with the spacers on. When I put the pads in for the track day I will mess around with spacers (with wheels that do not clear studs properly when mounted to spacers) and do more math, for the last time, for the 7th time.
    • Lucky pick up Best to find these things before something horrible happened to the yoke flange thingies I would hate to think what would happen if it dropped the tailshaft  Hopefully the holes are not flogged out in the yokes and it was just the bolts that got munted  As for the hand brake.....ouch, look like the disc got rather hot, and I assume smokey, I recall when I had a front caliper seize on the Commodore, there was lots of smoke and the disc was glowing cherry red when I was able to eventually stop and have a look, and stopping a big heavy car, going down a big hill with some rather high RPM down shifts and some hand brake action is something that makes you think hard about life
    • One of the things that never seemed right was the handbrake. Put in some nice new Project Mu shoes. We figured the rears were out, so why not. We're right there. My handbrake never worked well anyway. Well, this is them, 15km later. 67fdcf94-9763-4522-97a4-8f04b2ad0826.mp4 Keen eyes would note the difference in this picture too:   And this picture: Also, this was my Tailshaft bolts: 4ad3c7dd-51d0-4577-8e72-ba8bc82f6e87.mp4 It turns out my suspicions that one side of the handbrake cable was stretched all along were pretty accurate, as was my intuition that I didn't want to drop the tailshaft to swap them on jack stands and wasn't entirely sure about bolt torque. I have since bought the handbrake cables which have gone in. I'm very glad that I went to my mechanic friend who owns an alignment machine to get an alignment before the track day, because his eyes spotted these various levels of "WHAT THE f**k IS GOING ON HERE?". Turns out the alignment wasn't that bad, considering we changed the adjustable castor arms out for un-adjustable castor arms, and messed with the heights. Car drove pretty good with one side of the handbrake stuck on, unbleedable rear brakes, alignment screwy, and the tailshaft about to go flying and generally being a death trap waiting to happen! (I did have covid) (I maintain I adjusted the handbrake correctly, but movement caused shennanigans and/or I dislodged the spring on the problem side somewhat, or god knows what). G R E G G E D
    • Very interesting, im not sure how all those complications fit in to running a haltech instead of a stock ecu but I'm starting to think I'm a bit out of my league.
    • I just put 2 and 2 together. This is a Neo converted R32. The Neo ECU (in concert with the R34's AC controller) runs the AC quite differently to how the R32 ECU and AC controller do it. If you just drop it all in, it won't work. There is some tricky wiring required, including changing to the pressure switch that the Neo controllers want to see. I don't know what it is, because mine was done by a guru. It was a year or so after I did that transplant before he worked out what needed to be done.
