Jack stand on the chassis, tsk :no:
Word of advice with the HICAS light, don't just remove the bulb. If you ever need to get the car inspected, the pits guys know to look for that. All the lights should come on when you switch the key to on, if it doesn't they know you have removed the bulb. Best way to get past it is to wire that bulb into one of the other bulbs, so that it will come on when the key is switched on.
Strangely enough they aren't worried about HICAS being deleted, just the fact the light doesn't work. They're an odd breed.
Where's best for the stands? :S
Thanks for the tip on the light. In Dubbo it wouldn't be much of an issue. Most people don't even know what a Skyline is let alone HICAS :P . Good to know though as I plan to go to Sydney for some events along the way :)
Just FYI for next time, those aren't pressure plates. They are the clutch plates.
I love guys who are DIY and hands on :) So good work mate.
My bad haha. Like I said I'm not the most mechanical person myself, and I was relying solely on my friend to get all the work done. I was just a work horse so to speak hahaha.
Thanks for the kind words :) Hopefully I get to do a bit more myself, I love actually working on cars (especially my own) but just don't have the full know how to do everything on my own lol.
Hey with the Hicas bar on R34 is it as important as with 33 ans 32s because i thought 34s have the electronic Hicas unlike the Hydraulic ones that eventually break.Shed some light on me if im in the dark.
Hey, I'm a little confused by what you're asking. Do you mean is it important to replace to prevent it from breaking? If so, I'm not too sure, I simply fitted the lock bar to get rid of the HICAS I was want to get track my car (when I eventually get to it). I did not read into the 'reliability' of the HICAS in R34's to know whether they are likely to break or not. The only 'advice' I can relay in regards to that is that my car has just over 150,000kms on it and I believe it was the original HICAS unit. Hopefully this helps.
HICAS is broken from the factory.
Timmy which springs did you get? I have some incoming brand new bilsteins and searching round for a set of springs to match up!
I just bought second hand King Springs on ebay (I plan to fit coilovers at some point so didn't want to buy new).
I'm pretty sure King Springs only have one model number for front and one for rear so whatever that is sorry lol. I can look for pictures of the model numbers if you are stuck.
  • 1 month later...
Hey all. Competed in a local 1/8th mile drag meet today. Was good fun, even managed to take out the win in the bracket I was put into.
Photo from setting up in the morning.
Trophy ^_^
Will post some vids up when I get the chance during the week :)
  • Like 1
Here is a phone video, I'm yet to go through the GoPro footage.
Excuse the bad camera zooming (friend doesn't know how to use phone camera apparently :P) and the commentating. The guys that run it often talk crap but it's usually amusing haha.
  • 3 weeks later...
    • The connector led to nowhere, are you talking about which wires it was spliced into?
    • I'm about to go nuts. I tore apart the interior dash to trace back the headlamp wire to see if anything looked strange.. but nothing... everything looked perfect in the interior. I reluctantly grabbed my floor jack to jack up the car, removed the wheel, and I checked under the inner guard linings, but everything looked just fine.. There wasn't anything super obvious that was melted or bare wire touching metal. Everything was wrapped in the factory electrical shroud. If the headlamp wire was shorted somewhere inside the factory electrical shroud, i would have to unwrap the entire 3 inch thick cord from the drivers seat all the way to the fuse box in the engine bay to find the damn short.  I took a break and sat down to contemplate life and i wondered if its the relay. So i took the headlamp relay out and was googling how they work, but i couldn't find too much info on the 6-pin.  After about 10 minutes, i checked the headlamp socket to see if it was still being shorted to ground, and miraculously, it wasn't. I plugged everything back up and the headlamp is working now. I just have to put the interior back together.  but this part is the worst part, because i have no idea what i did that fixed it. I wiggled some wires around all over and now the short is gone..  Could it have been a bad relay?
    • PRICE  : $1400 LOCATION   : NSW Central Coast FIT  :  All Nissan 350Z type Z33 and Infinity G35 Coupe. See delivery note. Hi, brand new, unused, still in the box.  ($1850.00 is what i paid ) My bad luck !!! I thought my right front  Bilstein was cactus so i bought the ST 's to replace all.  Turns out the right front is fine ( loose mounting after service  by a well known importer of Bilsteins ) So im selling the ST's. They are made by KW ( no intro needed ) . Iam on the Central Coast and im willing to meet up in Sydney metro, within reason and Newcastle.
    • Yep, yeah would need to do the flywheel although the 6 bolt NA clutch can handle a 20de if just wants to replace the stocker.
