^^ Provided you're not planning on winning championships, the 2wd R chassis has a number of things that make it a good fun thing to own and drive on track. And you do get to the point of not being prepared to cut losses once you've gone down the path of track modifications. I'd say keep driving it if it makes you grin each time after a run.
The trouble is that I can't figure out anything specific to race in my car with, and in most instances it would still require quite a bit of modifying to meet standards for any type of regulation series. I do enjoy driving the car but just go through stages. It's alright though, I have gotten over the lull that I was in the other day and have no intention of selling my "no withdrawing allowed" piggy bank haha.
I do wish to move in the direction of competing in events where driver skill is more at play then how much money you have to spend on your car though, so we might see more happening in that direction in the near future, but for now, there are a couple of things that have just been brought in to the works that will definitely keep my interested ;)
I have Nulon Nationals Rd3 tomorrow, and will be arranging a full cornerweight/alignment with Heasman's for next month as well as fitting my new Hardrace LCA's as well.
I just put my entry in for Mount Panorama hill climb event next month so will compete at that and then will be making a couple of small-ish changes to the car after that ;)
P.S. How's you aero coming along?
The aero has stalled.
Focus on chasing a bit of MR2 setup and seeing the Evo running.
Time and effort and $$ on corner weighting is probably less critical than getting ride heights (meaning suspension arm angles) close to right, and spring/sway bar combinations within the right ballpark first. My opinion only.
  • Like 2
Turns out I am terrible at providing updates of late. Life/work is keeping me too busy to do much with the car besides attending Nulon Nationals Round 3 a couple weeks back now. There were a couple of small issues on the day but not chasing times I was able to run 1:10's consistently and enjoy myself 'playing' with other drivers/cars on the track.
I will post some pics/vids and a bit more information soon as there were a couple of small dramas on the day, unfortunately resulting on me having the trailer the car home. This is the joy of motorsport/modifying cars I guess lol.
I'm also excited to say that plans have become much more positive with the car and some further upgrades are in the works. More on this later also ;)
Let's see some in-car or it didn't happen ;)
Awesome work Tim!
I realised that I didn't put a lot of information up regarding the big brake setup, so for those interested, I have written a review and put it in the Suspension/Braking section on the forum.
You can find it here - http://www.sau.com.au/forums/topic/459054-review-alpha-omega-racing-350mm-brembo-front-brake-adaptor-kit
  • 4 weeks later...
Been a bit slow in doing the rear brake conversion but it should be all back together next week. I have disassembled the calipers to repaint and rebuild and have been quite busy as well so progress has been a tad slow.
I also had a delivery today. More news to come soon.
Excellent progress mate youve done so well since the beginning of this thread Been following you more on your fb page..
Thanks mate :) . The car and myself have definitely come along, and the bank account has definitely gone the opposite direction lol...
Dare i say thats hypergears atr45sat?
:ph34r:
  • Like 1
Finally finished rebuilding my calipers and got the brakes all fitted up to the car.
They are a perfect fit,very snug though.
I haven't been able to really take the car for a drive after bleeding up the brakes, being Bathurst 1000 weekend there are far too many highway patrol around for any nice daily driving. The Skyline cooincidentally got defected this exact day last year so I wasn't going to let that happen again lol. Will get the pads bedded in during the week before heading to WTAC in it :)
that certainly looks like a tight fit.. if its less than say 5mm of clearance id be worried about flex rubbing the caliper face
There is actually a reasonable amount of clearance between the spokes and the caliper if that's what you're referring to?
    • Given by the sheer number of questions about offset, absolutely not. If you had the information formatted this way: Space from R34 GTT hub to outer arch = 100mm Space from R34 GTT inner hub to nearest suspension arm = 90mm. (making this up) Buying a wheel that was advertised as Enkei RPZ5 Diameter 18in Width 9 Distance to arch = 84mm Distance to suspension arm = 76mm 100% of people would know instantly if it fits. They would absolutely also know instantly how close it fits too, and no questions would need to be asked. You would know you would have 16mm from the guard and 14mm from the suspension arm.
    • Ah ok, for example for the apexi ecu I heard that it's pretty limited with the information it can give you. Also not sure why Nissan used the consult port over the obd2, what the idea there was.
    • Diagnosing with and without is mostly the same. You need to know, as Duncan asked, and what conditions. Car hot, cold, idling, driving, if while driving what rpms, is when you're varying, or is it when held constant.   From there it's understanding what can be causing it. Starting with pretending all of the sensors are correct. Which means if it's going rich, why would it be thinking more air is going in than it is, and under what conditions. So things like if only when under boost, it could be be a loose intake piping joint. It's just understanding the system, and understanding when/how the problem occurs, and then if it's only occuring in specific scenarios, what can be causing it.   ECU specifically, if it's aftermarket, it'll have software you can use, for the Skylines on factory ECU, there is Nissan Consult you can use. Most ECUs have a way to get data from them.
    • How do you go about diagnosing ecu's that don't have data logging, is it more experience at that point and just trying out things that you think will fix the issue?
    • Stock O2 are basically useless beyond anything at stoich. Any misfire will also be seen as lean. The stock O2 also read a collective exhaust gas volume, not each cylinder. Sputtering and missing means not each cycle is firing, and some are. Which means even if rich, as shit, on cylinders as they miss, they'll read lean, but the cylinders that did fire will read rich, and combined, well, they can read anything from rich to lean.   Start with the basics before even going looking at sensor values.   Edit: I say the above, and that's coming from the guy with a few thousand dollars worth of scan tools sitting right beside me right now that I use frequently for my job.
