Nothing comes easy with performance setups.
However - maybe the ITB setup is over-rated.  eg. Nissan persevered with it on the GTR and GTiR.
No sign of it on the VR38 engine, and Mitsubishi never put it on the Emo range.  Surely throttle response/control on a rally car is an important factor to performance?
In the case of the GTiR, ITBs are too much effort for what they're worth.
N/A it makes a bit more sense, and the setup is a bit more basic, but for forced induction... It makes no sense to me.
  • Like 1
On 10/16/2017 at 5:38 PM, Jordy32 said:
That plenum adapter is a shame, I asked Matt about it after seeing it installed on your car and he showed me a number of photos which look identical to the ones above. It's possible but no way is it as "bolt-on" as Otaku Garage claim..
From seeing how it was made to work in person I can confidently say there's no way they actually bolted an RB26 plenum to an RB25 head with this adapter.
Not sure what you mean? They definately work just need a decent amount of modification to existing parts which is not disclosed anywhere
  • 1 month later...
For anyone wondering what work is involved in getting the OtakuGarage ITS adaptor working, it's a lot. Firstly you have to get your RB26 coolant rail modified to clear the thermostat housing outlet. This is a fair bit of work and is certainly a job for a fabricator. When doing this you have to removed enough material for it to clear but also leave enough to not create a bottle neck in the coolant passage. Then you have to find an RB30 thermostat housing as a normal RB20/25/26 one won't work without a large amount of grinding on the acutal ITB's. Then you have to replace the bolts with M8 studs and nuts, and the top stud has to be shorter than the others. Then you have to grind  away the lip around the outside of the RB30 theromstat housing, and grind even more away where the bolt for the coolant rail will foul the housing. It is a small mission but doable.
You should be able to see most of what i am talking about in these pics.
  • Thanks 1
Whoops, forgot to post the pics. But yours are basically identical to what I would have been posting. Cheers.
Got any pics of it fitted up in the end? Noticed you havent posted an engine bay shot since the update :)
Well what do you know, I haven't either haha. I'll get one up soon when I provide the remainder of the updates for this year.
  • 6 months later...
Hi, sir... I found this thread doing a search and it is nice :)
I was asked (as often happens) to try and match a nice turbo for a mates RB25 track car with some very specific requirements, ie ball bearing, within a limited budget, T3 open flanged and able to make around 450kw @ hubs on E85 on a Dynapack dyno.   I did some crawling around and decided to pay more attention to the GTW3476R than I had really given it previously (Garrett took AGES to release flow data for them) and I was actually pretty blown away by the match that they give, at least on paper.   They actually look like an awesome combination from that point of view.
How have you found you found yours so far?   Real world response etc fairly acceptable for the power you are making?  Was that power figure "all in"?
Cheers
  • 4 months later...
Cheers
Thanks mate. Sorry the delayed response, don't really frequent on here anymore.
Have found the turbo to be great for what it is. I'm running the bush bearing version. Was previously running the .86 twin scroll rear housing which made 420rwkw on ~26-28psi. Response was great. We've recently changed the setup to a 1.01 rear housing to help with getting more heat out as I kept melting the diaphragms in the gates. As a result I'm currently making 370rwkw on 22-23psi (need a new boost controller) and I'd say a few hundred rpm laggier, but much nicer curve coming on. Will put together a big update post eventually, but feel free to pm me if still looking for info.
  • 5 months later...
Well guys, the time has unfortunately come. I guess I'm turning in to an old fart as my baby for the last (almost) 7 years is up for sale. If you know anyone that is keen, link below with as much info as I could remember.
Well that was unexpectedly quick, but I guess this chapter of my life has finally come to an end. Car is sold (getting picked up this week). Big thanks to everyone on this forum that helped out in one way or another, or just talked banter. See you all around once I figure out what's next :)  ?
  • Like 1
  • Sad 1
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
