The regs said 95db limit, but they didn't have anything to test it. There were a couple of cars running screamers and I'm sure they would have been at least 110db LOL. You'd fit in fine ;P
Let me know when the next decent event is on and ill try make it down ;)
For sure man :D
There is an Esses Descent planned on the 30th March but not 100% sure if it will go ahead.
Hillclimb on Mountain Straight on 31st August, Supersprint on Conrod on 2nd November and again the 29th November as well as a Hillclimb on Mountain Straight again on the 30th November.
For sure man :D
Oh nice! Well ill have too pick the one that suits my car best :P Can i just do conrod by itself? :laugh:
Yea man, the Supersprints are just Conrod so you could just do one of those days. But I will insist that you do a hill climb as well man, would love to hear your car hitting gate all the way up the mountain :D
If they let me that is :P Would be keen to give it a crack :yes: I was pretty jelly once i knew you were there!
Well, when people say that Jim Berry likes to talk, they don't lie :P . I was on the phone to him for about an hour and a half total today, but I learnt a lot (and a lot passed right through one ear and out the other too! haha). I have now ordered a custom clutch and new flywheel from Jim himself. It is almost the same as what Mat (34GeeTeeTee) is running, a 6 puk solid single plate, except with 5000 clamp pressure. It is a bit overkill for my car currently but I am hoping that I will never have to replace it :) . Jim said he would get a start on it and give me a call back in a couple of days, so hopefully I'll get it sometime next week maybe then I can figure out exactly when I will be able to get help fitting it :P
Edited by timmy_89
Juts got a call from Jim to say he is sending the clutch/flywheel ^_^
Wow, he musnt of had too many phone calls today :ph34r:
(If he reads this i hope he laughs lol)...
Yeeep. Haha. Oh well, now I have some spare seals I guess :P
I know we had trouble getting the rear main seal right on mine, check it over and make sure it is 100% before fitting :yes:
He mentioned having trouble with the rear main, I'll line it before removing the old one and make sure it all looks right :)
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
