Ok got a wear hole in my R33 drivers side seat and yer it annoys me even though its small so i am looking at a few options to what i can do obviously Seat covers is cheapest but i have been thinking about R33 GTR seats.
I know they fit and all but was abit suprise at one place i looked at a pair with door card match @ $1400 is this the going price cause i was only thinking id get away with them for like 300-400 buks or maybe another car with alot of electric options on the seat and get that in there but i want that sporty feel though.
Or i know i can get a pair of WRX seats heaps cheaper and just mod them and wack them in?
Or get a full set of aftermarket seats with rails RECARO,BRIDE or somthing.
Or last idea is reapholstered getting the GTS25T seats Redone sounds good at 1st though it dont have the hugg a bility of the GTR or WRX seats around the sides you guys know what i mean unless they can bolster them or somthing but ill still have the GTS25T style headrests.
Your Thoughts please.
https://www.sau.com.au/forums/topic/421422-worn-seat-driver-side-my-options/
if you're gonna pay for something then don't pay for the same thing (ie don't get the same seats)
so upgrade to GTR/recaro/bride etc. would be my thoughts.
I'm in your shoes though, my seat actually just has a big 'crease' in teh fabric on the corner, seems like it's been sat on for a long time just on the edge...so i went and bought seat covers less than 100$ now looks a LOT better and out of sight out of mind until the time comes when i find the right pair of seats to swap out. No rush, it's not broken, but a little money spent on the covers made me a lot happier.
+1 to Temporary covers. I think mine came from Aldi. LOL
My seat has the "Driver gets in, Driver gets out" wear hole on the door side, my cover is starting to get it too.
Might be time to swap the driver / passenger covers over.
Outa sight outa mind and save dollars til you get to upgrade. :)
Asked a "motor trimmer" for a free quote? They can even strengthen the supporting rubber if required.
Michael at 17A Amax Ave Toongabbie - same estate as Unigroup Engineering - is good at his trade.
yer mine is the in out wear hole aswell yer if im paying 150 for retrim it would be great but like if its 300 plus im better off getting another style seat and reweld stuff to make it fit.
I dont think i found a quote under $580 for a steering wheel. I could only imagine what a pair of seats would cost.
I picked up a mick pair of 32 GTR seats for under $500. Just keep looking around. They are the best seats of the lot i rekon.
yer its kinda a joke when i see some of these prices people want for rice parts like weather shields and stuff has anyone thought of making Aftermarket parts for these they would make a killing.
has anyone actually got a auto trimmer to repair their front seat? or a quote on it?
i'm in the same boat at the moment... most seat covers i've seen look sh!t lol and when I do find a set that are a good fit etc, they are expensive!
I think i'll look around for an auto trimmer in Perth and when im back next week, go get a quote as well :)
It cost me about $150 to mend the bolster on my R33 GTR I think. The trimmer did a perfect job.
    • Dissimilar metal corrosion. Aluminium is less noble than steel/iron, and will corrode preferentially when in contact with it and a conductive solution (ie, wet road salt). Tends to suggest that those brackets should be made in steel for a shitty climate like the UK.
    • Here is picture of the rear brackets again seeming to have eating itself or corrode or whatever. Can’t describe it , hope someone could explain this
    • No i am in the uk so maybe road salt etc but checked rear and same story where handbrake cable seems to have eaten part of the bracket. Have emailed alpha omega waiting for reply
    • I've not looked at a GTR without the booster there. Is the hole and mount on the firewall not just the same as GTSt? I would have expected it to be. Nissan don't change panel stampings if they don't have to, and you'd think they'd just order/design the booster to mount to the same place.
    • They have all sorts of "failure" modes. When they are brand new, the can either be very very tight, or reasonably mobile. If they are reasonably mobile, you'll probably have a good start. If they are very tight, then they can catch/grab at every little motion, and they mark the ball or the outer race, tearing off whatever teflon lining is in the outer race, then they can rapidly degenerate from there. If they get wet, they can just rust. They are just steel and will turn red pretty quickly. Water can get in behind them and sit and cause them to become crunchy and then proceed to tear themselves up, as above. Same with grit and dirt. Manufacturers and OEMs of the arms that use them will tell you that because they are teflon lined (well, the good ones, anyway), you shouldn't grease them. If you do grease them, then the grease will catch any passing grit and dirt and hold it in place where it can cause damage. Race teams that have them will lubricate them thoroughly. They will also inspect them every 5 minutes and replace them every 10 minutes, if need be. Some manufacturers of arms will provide dust boots. These can help, but they are seldom perfect, and sometime just make the situation worse, being a place where crap can collect. I have made nappies for some of mine with PVC sheet and race tape, to try to minimise the access of crap. When they wear, you can get a tiny tiny amount of movement between the ball and the outer race. This will make clicking noises. It will also make the arm have "slop" in that the tiny amount of movement available at the inner end of an arm can cause a lot of movement out at the outer end. 0.05mm at 5mm from the pivot becomes 4mm 400mm away from the pivot. If they are too tight and binding, they impede the proper motion of the suspension arm and put loads into it and the rest of the suspension that are not supposed to be there, and can cause failure. Think broken welds, broken threaded sections on the adjustable parts, mounts ripped off the chassis, etc. All of these are possible, which is the main reason why they are essentially illegal on the road in Australia.
