Well after a very hot night I only managed a14.4 my car didn't like the heat track temp was28 degrees but I did get a 60 foot time of 1.956 :)
I'm still the king of Eastern Creek. :whistling:NM35's anyway...
Good on you for getting out there mate!
https://www.sau.com.au/forums/topic/421430-400m-drags/#findComment-6783712
1650kgs I think I recall, on my sticker.
RMS, Dale, RMS..... because in government land changing names fixes all problems ever associated with the the old organisation...
Even on their own website; parts of the organisation are still referred to as RTA.
So f**k em.
https://www.sau.com.au/forums/topic/421430-400m-drags/#findComment-6785739
  • 1 month later...
thought I might leave this here.....I know it's not the greatest time but!!!!
It's a mate of mine in QLD.
SS1 turbo, Dales Suction Pipe, Scott dump, Custom Exhaust, Scott actuator(remodded), E-Boost 3, Transgo Shift Kit and Impul ECU.
Things to note. It's an AR-X and its on standard injectors.
https://www.sau.com.au/forums/topic/421430-400m-drags/#findComment-6843966
Kick arse result; seriously good bang for buck mods.
Nice effort. Emanage and do 12s maybe.
Meh, 13.1 without an E-manage; I'd take that & enjoy never having to worry about it.
https://www.sau.com.au/forums/topic/421430-400m-drags/#findComment-6844130
I agree, as long as the afr's are ok why bother. At least the Impul gets rid of the AFM cut.
If you went to a larger turbo than that you would have to back out timing too, as it is the impul would be running a crapload more timing than my map...
https://www.sau.com.au/forums/topic/421430-400m-drags/#findComment-6844141
    • No not yet.  Hopefully this weekend if I can pluck up the confidence!  I had to sit in the car at one point yesterday to unbolt the rear struts.  As mentioned in an earlier post when I was putting it together there is still a bit of rotation possible so when I sat in the car, it rotated a little bit.  I near shit myself thinking the whole thing was coming down!  I do 99% of my own shit in the shed but I think I might call on some assistance the first time I spin it!
    • Strong first post. On a Skyline-centric forum. Have you considered actually going out into the world, visiting the actual dealership, and asking the parts guy over the counter? Or at least just call them up on the phone?
    • Should shit that in as for the driver ability probably not
    • Trying to find the plastic under cover for an 04' Forester X. The main under cover that covers most of the front of the vehicle under the engine. This has turned out to be a crazy experience. Normally I can find parts for vehicles, if I have the correct info, no problem. But not this! The Forester is a non-turbo btw. In a Forester parts catalog, for model years 03'-06', it shows part# 56410SA070 as being the correct part. So I go to the local Subaru dealership's website to order it. I type in the part#, hit search and there it is, the under cover. "DOES THIS PART FIT YOUR VEHICLE?" I type in my VIN# and sure enough, "This Part Does Not Fit Your Vehicle. See Similar Parts For Your Vehicle." I click on that and part# 56410SA000 comes up. Looks absolutely nothing like the previous part. Not even close. So I go to a different Subaru dealer website and put in that 2nd part# (56410SA000) and "This Part Has Been Replaced By" 56410SA070, which is the first part I looked up. I thought OK, makes sense. They replaced the strange looking part, with the one I looked up first, so I add it to the cart. "Does This Part Fit Your Vehicle?" I type in my VIN#, and sure enough, "This Part Does Not Fit Your Vehicle." I've basically been doing this with various parts suppliers and dealerships, for the past 4 hours! Does anyone know what the hell is going on?? Thanks in advance!
    • have you rotated the car yet? if so how smooth was it?
