Thank you to all at SAU for making my first time at a grip event an enjoyable day. I was pretty happy with the GTR. I think its the first time in 3 years it had a decent thrashing. I just need to get my times lower.
Hope all is well with the Fliggymobile
  • Like 1
Great day guys, big thanks to everyone who played a part in organising it! I threw a power steering belt on my first lap of the day...so off to Repco for a replacement. Thanks to the lads who gave me a hand to get it changed over quickly and get the s14 back on track asap! Ended up pulling a PB with a passenger in the car...first time I've done that! Did a solo run after and ended up getting another PB of 1:16.01!! Very happy with how the new tyres/alignment went, was also good to meet a few new faces.
Awsome day taking the new 32 for it's first grip day. Massive thanks for the SAU SA Exec team for organising the day, great work and the layout worked really well. Hope next time I can have decent tyres instead of 205's all round.
Massive thanks to Munro for the burn in the 33, best car I've ever been in.
Had a blast on the burn out pad at the end hence why I went back out. Ended up splitting a heater pipe at the end so spose that's good compared to what else could have happened and car will be fixed Saturday.
Fliggy
i know i just brought a new turbo :w00t:
Didnt take long, oil cooler arrived this morning! Thanks Australia post.
A HKS 2540r is on its way, maddddddddddddddddddd. anyone know all good places to get a custom intake made
or a club sponsor
https://www.facebook.com/pages/AM-Performance/135203453221377?ref=ts&fref=ts
yeah i rang him today and he will make me one. So getting the built
need to get manifold modified which is sorted injectors fuel pump and another tune.
Has anyone ran/run this turbo? any good
    • have you rotated the car yet? if so how smooth was it?
    • And finally, I had the driver's side airbox off while adding a long drain hose under the oil can to down near the oil filter. Doesn't look good, it has definitely had an turbo oil seal leak and looks like it has been for a long time.....guess I'll have to get a pair of highflows to put on the shelf It's also worth mentioning it has a really strange clamp between the bottom of the airflow meter (which has a big barb/lip on it) and the intake pipe. I've used the magic of MSPaint to show, basically you have to clip out those 2 steel springs which unlocks the hose from the AFM. I used 2 flat screwdrivers, the spring sort of clips into the unlocked position. Reassembly you just pop them both back flat once the hose is far enough up the AFM that the spring clamp is above the barb. Weird to use but much more convenient once your'e used to it compared to trying to do up a hose clamp under the airbox like on 32 GTR
    • The other thing I started was a fire extinguisher bracket.  As with a few other cars previously (350z, Leaf), I'm going to add a bracket between the navigator seat's front bolts, then mount the extinguisher on that. Unfortunately Nissan (probably the same engineer who did the A/T fluid interwarmer) decided that the front seat brackets would be recessed and uneven so the bracket shape was a bit tricky; I ended up doing 1 part under each seat mount (the large hole is because there is a flange under the seat mount to allow for the carpet thickness)   and then a horizontal part between those 2 No final pic yet as the paint needs to dry, I'll post up once that's done
    • OK, a few half jobs on the skyline this weekend because its booked for a test day at Wakefield Park on 27-Feb. While the Ecutek dongle and app provide display and logging of a heap of engine parameters, they annoyingly don't have access to the auto trans temp. So I grabbed an oil temp gauge from Raceworks which apparently has warning colour change and peak hold, about $95  and their 8mm hose sender adapter Now, I foolishly thought these 2 might work together, but no, the sender needs about 30mm clearance in the fitting and the adapter only had about 8mm. I've cobbled something together with an NPT T piece and blank for now but will try and work out something more permanent as I intend to use the same fitting for the data logger in the future. Under the car, Nissan's engineers decided that only one opportunity for coolant and trans fluid to mix (the radiator) was not enough, and they also added an interwarmer near the sump on the passenger side like the engine oil has: I've cut the hose between the auto trans outlet and the interwarmer inlet and inserted the sender there as that gives the best indication of temp inside the transmission.   From there it is back to the pain of running that sender wire to the cabin, I've run it up near the passenger headlight, into the battery box, across the channel at the back and into the master cylinder area where I ran out of wire length (and patience). Remainder of the job is through the grommet near the accelerator pedal that I've used previously, then across under the dash to where I will temporarily mount it on the console for track days (and remove it other times). The gauge will also need IGN, BAT and earth (I'm not going to worry about illumination as I'll unhook it between track days)
    • This piece is obscenely discontinued. I honestly hate the frameless window design because the rubber gets stressed and the guides as well every time you open and close the door.
