Sau:sa Track Day #7 - With Passengers!
SAU-SA Exec
 Share
I win. I will be bringing an extra 40L
This sounds like war lol..........I could go to work and grab our 2 30L Jerry Cans :P
I see no problem with a late entry...
Just ensure that you have the required protective gear such as an ADR approved helmet and cotton long sleeve to and jeans etc
We will be at the track from about 8:15am onwards.. If you have any other questions just ask :)
What an awesome day! I rocked up with both GTRs full of E85 & used 8 jerries full as well!
Heaps of passenger rides & some great solo sessions. Even a bit of paddock work out in the middle!
Did a PB today of 1:11.9 & a bunch of 12s. Pretty happy with that from the R33.
The R35 was running in the 16s so need to do some work there!
Overall a fantastic day & as it was raining most of the day in town we were lucky to have a dry track.
Thanks to everyone again.
See you at the next one.
Munro
Was a great day guys, thankyou Munro for the burn in the R33, I'm still putting my organs back in the right spots!
Obviously I'm a bit biased because I helped plan this day, but I think it was the best one yet. We ended up with 22 cars on track, which blew apart any thought of a quiet day, and the atmosphere was awesome. We had about 5 drifters come and try some grip, along with a handful of first timers, as a result we had a huge variety of cars, engine and suspension setups, which made for some very interesting viewing.
Probably the biggest plus of today was the weather, nobody overheated, and nobody got wet, how good is that! The showers were looking a bit threatening at a couple of times, but obviously recognised the importance of an SAU-SA Trackday.
As stated thank you to everyone who helped organise the day and also to everyone who came to enjoy the track and their cars...
I also need to thank Munro for the laps and for the paddock work as well.
I am not totally sure but I swear I heard you laughing as we were spinning around and around... :P
Oh and last but not least FLIGGY nice way to end the day on the burnout pad ;)
 Share
    • The two diagrams are equivalent. The R32 one is just one sheet out of about 3 showing everything in the whole car all at once. And without knowing the functionality that occurs in the modules, they are both equally opaque.
    • 8v - 2.48ms 9v - 2.15ms 10v - 1.74ms 11v - 1.41ms 12v - 1.15ms 13v - 0.99ms 14v - 0.89ms 15v - 0.82ms 16v - 0.81ms I'm running these values on my RB20 Neo with 570cc Denso R35 stock jets and it's great. Also bought a set for my Legnum VR4, love these injectors!
    • Thanks for your reply,  Those blue/green wires running to the actuator aren't attached to anything, so I'm not sure how the central locking is still working. I will have to take a good look tomorrow, I don't have the car with me. After googling it seems like a pretty common aftermarket actuator which even uses the same green/blue wires the immobiliser required. i'll test everything tomorrow and if it's working i'll melt the solder, strip it, resolder and neaten it all up with some heat shrink. I don't have to understand it if it works hahaha I just don't want a fire/ short circuit. That R32 diagram looks more like a continuity chart? Can you make sense of this form the R34 manual? 10V is probably due to very flat battery, i'll recheck as well tomorrow, I did have to jump start it haha. Thanks again!
    • So, COM doesn't mean comms. It means common. What common itself means will depend on the type of device. For a two directional actuator (ie, one that can push and pull on the same output rod) then the common will typically just be the earth connection. There will be at least 2 other wires. If you put 12V on one of the other wires, then the actuator will push. On the other 12V wire, it will pull. Can't quite make out what is going on with the wiring of your actuator. It appears to have several wires at the actuator plug, but there only appears to be 2 wires where its loom approaches the door control module, with at least one of the others cut off. I don't know these actuators off by heart. I'd have to look at a wiring diagram for one before knowing what the wires were about, and that's despite me having to replace one in my car not all that long ago. Just not interesting enough to have dedicated memory set aside for trivia like that any more. That actuator is an aftermarket one, not the original one, which probably died and was replaced. That might require some sort of bodge job on wiring to make it work. Although nothing should justify the bodginess of the bodge job done. As to the soldering job on the door module's loom plug. Ahhahhahaha. Yes, very nasty. Again, I cant tell you what any of those wires do. You'd need to study the R34 wiring diagram (if you can find one that shows the door module). I don't think I have any. I'd have to study the R32 diagram to start to understand what mine is doing, and again, even though I've had a problem with mine for the last 25 years (where it locks the passenger door when the driver's window reaches top or bottom of travel) I'm just not interested enough to try to to work it out. So long as it's not burning down, it's fine with me. Here's the R32 GTR diagram, which, confusingly, has rear door lock actuators and window motors on it!! As you can see, unless you understand the functions of the door lock timer and the power window amplifier, you'll never be able to work out how it works just from the diagram. I don't imagine that the R34 one is any better. Hopefully an R34 aware bod can help. FWIW, the two wires that are cut and joined look like they are both power supply - so hopefully it is not fatal to join them. The 10V you measured on the cut off free end of one of them is concerning. You'd expect 12V, and it might be the reason for the bodge job joining them together.
