Hi Guys,
I haven't searched around and haven't been able to get the answer i am after.
I'm really interested in the exoticspeed r1-t exhaust (catback) and was wondering if anyone has the same config and can tell me whether they experience in-cabin droning on normal street use.
Or if anyone has a catback exhaust with minimal droning that they would recommend...
Thanks in advance.
i got the exotic speed......its pretty good on normal street use....its loud when only when u hit the gas hard...however, on highway driving you will notice the drone effect...not a lot but still u will have some drone effect....i am assuming u will have that in most exhausts.....i may be wrong...
Hey Shiva, you reckon you can measure the length of your system from y-pipe back for me?
Sorry dude, i dont think i can do that but will try to drop into my mechanic and see if i can do it but on another note, I got mine from a SAU member in perth, myself and a friend of mine fitted it into the V. It was pretty tight. Later took it to a mechanic and found that there were some heating issues at certain places as the exhaust was too tight and close to the body. Took it to a muffer shop and had to weld a piece into the exhaust to make it fit perfect.....so would suggest you look into the dimensions right....
I have the Exoticspeed R2 titan Si on my 370z and if there is one thing i can suggest if you are looking at getting one of these exhausts, do as i did and get the silenced version I cannot imagine how loud the non silenced is when you step on it hahaha. But there is little to no drone (except in high gear going up inclines ofcourse) and I am running the system with the Exoticspeed high flow cats to match. As for the fitment on my car (I purchased mine from exoticspeed in canada direct (6 days to get it here and i live in rural qld thats nuts)) its perfect, tips aligned beautifully couldn't be happier for $1400 delivered!
I give it a 10/10 and my mates agree with me.
the thing is Joshua has got it on his 370 and not a V35....the exotic speed exhaust for a perfect match for the Z's however since the the body length of the V35 is bigger, it might be short of few inches, as i said earlier, i was able to install it without any modification but it was tight....to have it free falling and sit perfect, you might have to modify to fit....i got the exhaust for $600 (6months old) and spent a $100 for modify to fit...so am happy with the outcome....i still saved money and no one is going to look under the body to see the exhaust weld...
on another note, i can measure the stock exhaust length which is sitting in my garage, maybe you can cross verify the length of the exotic speed specification to see if it matches that...if you want to, I will do that...
The only way I have seen aftermarket exhausts stop the drone is using Helmholtz chambers to reflect the drone frequencies back. Some of the better Japanese companies use these in their Jasma designs, also seen on the ark test pipes I believe. As it requires a large amount of R+D they are usually the more expensive systems.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
