Hey All,
I have everything you need to give your standard RB25 / R33 at least 220RWKW, people have been known to get upwards of 240kW out of this particular turbo.
The PowerFC has been tuned for this setup, it was originally tuned for an R34 (OP6) Highflow making 250kW at the treads, but that setup proved too laggy and the power sacrifice is probably worth it for the 1000rpm quicker spool time, the tune has only been adjusted in the lower rpm with ignition timing removed due to the quicker spool time.
The PFC was tuned with the Z32 AFM and the JECS 550cc injectors, both which were new at the time of installation and have done maybe 10,000kms. The turbo is a GCG R33 highflow (not OP6) with zero shaft play and is a direct bolt on replacement. I have only ever run this turbo on 12psi due to only having the factory dump pipe installed at the time of dyno (and as you can see, holds strong), the turbo is good for 14psi but I never had the chance to run that before the car was written off.
I would recommend the ignition timing be set to 15BTDC, an upgraded fuel pump (040, Walbro 255, GTR, etc), boost controller and FMIC be installed with these components, then this should go straight on the car without issues, tune adjustment on the dyno might yield slightly more power for the less aggressive turbo but as is the tune is safe and reliable.
Pictures are attached, the injectors are still in the engine to keep then clean, i will individually snap lock bag them for postage. Note, the second graph is of the original tune for the OP6 highflow, first is with all the gear listed as dyno'd with a greddy profec b, Bosch 040, generic pod filter, standard coilpacks, ebay FMIC kit and 3" exhaust with stock dump.
I'm after $2000 posted (registered/insured) for the Highflow turbo, Tuned PFC, 550cc Injectors and Z32 AFM with plug
I also have a Profec B Spec II boost controller, matched to the setup which i wanted to sell separately, after $250 posted.
http://img547.imageshack.us/img547/4977/image009j.png
Hey, I will separate but the fewer packages/trips to the post office the better.
Chillzi, I would be after $1200 posted for those parts combined.
  • 7 months later...
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
