Hey All,
I have everything you need to give your standard RB25 / R33 at least 220RWKW, people have been known to get upwards of 240kW out of this particular turbo.
The PowerFC has been tuned for this setup, it was originally tuned for an R34 (OP6) Highflow making 250kW at the treads, but that setup proved too laggy and the power sacrifice is probably worth it for the 1000rpm quicker spool time, the tune has only been adjusted in the lower rpm with ignition timing removed due to the quicker spool time.
The PFC was tuned with the Z32 AFM and the JECS 550cc injectors, both which were new at the time of installation and have done maybe 10,000kms. The turbo is a GCG R33 highflow (not OP6) with zero shaft play and is a direct bolt on replacement. I have only ever run this turbo on 12psi due to only having the factory dump pipe installed at the time of dyno (and as you can see, holds strong), the turbo is good for 14psi but I never had the chance to run that before the car was written off.
I would recommend the ignition timing be set to 15BTDC, an upgraded fuel pump (040, Walbro 255, GTR, etc), boost controller and FMIC be installed with these components, then this should go straight on the car without issues, tune adjustment on the dyno might yield slightly more power for the less aggressive turbo but as is the tune is safe and reliable.
Pictures are attached, the injectors are still in the engine to keep then clean, i will individually snap lock bag them for postage. Note, the second graph is of the original tune for the OP6 highflow, first is with all the gear listed as dyno'd with a greddy profec b, Bosch 040, generic pod filter, standard coilpacks, ebay FMIC kit and 3" exhaust with stock dump.
I'm after $2000 posted (registered/insured) for the Highflow turbo, Tuned PFC, 550cc Injectors and Z32 AFM with plug
I also have a Profec B Spec II boost controller, matched to the setup which i wanted to sell separately, after $250 posted.
http://img547.imageshack.us/img547/4977/image009j.png
Hey, I will separate but the fewer packages/trips to the post office the better.
Chillzi, I would be after $1200 posted for those parts combined.
  • 7 months later...
    • Update time!  The JZX110 had some maintenance needing to be done, so a lot of the seals with replaced to fix some oil leaks. Also used this opportunity to whack on a front mount that I'd bought some time ago.  I also finally got the rear lip painted and fitted.  I then got the exhaust done. It's just a catback for now. Custom made 3" stainless with a turn down. I could have a tip coming out, but it will require cutting the rear lip and possibly the bumper itself. So far I do like and it's made the car a little more zippy.  Close out with some nice pictures of the cars and a sneak peek of what's next.
    • Once you learn it all, you find you do the job once. But this is the best way to learn, as you won't forget the lessons
    • Edit: It's now known as "R Performance" and is still in operation.
    • This lady loved her FD for 25 years!  https://www.topspeed.com/80-year-old-woman-donates-fd-rx-7-mazda/ My brother in law. He's nice enough to let me drive it whenever. He'll likely not see this, but I'll try: @r-is-for-fun got any pics?
    • Just something I found searching for more info on Emotion R, apparently the ECR33 Skyline GTS25t was either originally black, or there were two of them, the black one being the original demo car, then building a white one which was part of the 1997-onwards (to at least 2008!) Cockpit Tatebayashi Tokyo Auto Salon booth demo cars. It appears that Emotion R closed down in 2008 and was declared bankrupt in 2010: http://bank-db.com/hasan/208365. Scan of a magazine with the black R33 from 1996: Wayback machine archived page from May, 2000: https://web.archive.org/web/20000529061027/http://www.emotion-r.co.jp/skyline.html Option magazine with a few photos from the Cockpit Tatebayashi booth at the Auto Salon from various years: 2002: http://www.jdm-option.com/photo/index.php?action=item&category_id=154&image_id=3507 2003: http://www.jdm-option.com/photo/index.php?action=item&category_id=137&image_id=3033 2005: http://www.jdm-option.com/photo/index.php?action=item&category_id=116&image_id=1831 In 2008 Cusco website mentions that the Cockpit Tatebayashi ECR33 was displayed at that year's Tokyo Auto Salon: https://www.cusco.co.jp/event/2008/12/post_735.html As of 2021 it appears that the ECR33 demo car ended up being exported to Florida, USA: https://rmcmiami.com/inventory/1996-nissan-skyline-r33-cockpit-tatebayashi-demo-car-big-te06-turbo-endless-brakes-lsd-450hp/ And finally here's Google streetview of the Emorion R garage in 2023 which is amazingly not only still there, but the showroom is still full of various parts in stock and funishings, etc.: https://maps.app.goo.gl/ttyEAZdZLyzermyT9 Apologies for nerding out a bit. I used to love doing this 20 years ago on SAU and got a bit nostalgic for a moment... 😅
