Hey Homies!!
Sorry ive been so lazy over the last year and a bit,
alot of stuff came up and the project got pushed back as usual,
on the + side i done a nice big tour of Europe, got engaged & done another drifitng to Japan.
The car has come along way since last photos last yr and is only approx 10 weeks from being completed.
Over the next couple days ill slowly upload all the New photos.
Thanks Guys!! :cheers:
1st time everything was bolted all together
I dont know if you've mounted an aftermarket seat in you 33 before but if you have you'll realize what an obscure angle the front of the seat kicks up and how high you are actually sitting, this is why i took the grinder to the factory floor mounts and fab'd up my own so my legs sit in a very comfortable postion
Subframe all braced and gusseted, solid bushes throughout and a fresh coat of paint. Has a kaaz 2 way i put in there only about 6 months before i took it off the road
This was the lock with the gk tech knuckles, currently no lock stops welded in. Was having lots of troubles going over centre on full lock, since then i have decided to change to PBM front knuckles due to a personal choice and the powersteering rack has been moved forward.
all tacked in
Looking good!
Will the outside be the same colour as the inside?
Nah i have a differnt color for the outside, i sprayed the fender my new color for a sample which ill put up :P
Engine bay is coming along nicely, this is how it currently sits as im still waiting for my motor to be finished from sydney.
New switches for the Dash.
Motor almost complete, Just waiting for oil pump to rock up from the states and where good to go.
Hopefully my new engine loom from chasebays rocks up this week so i can start chipping away at the rest of the wiring this weekend and switches
  • 1 month later...
Out the shed to send off for the rest of the fab work. Ic piping, exhaust, tailshaft, oil/fuel lines in bay, brakes lines.post-60275-0-78514300-1413841266_thumb.jpegpost-60275-0-86246700-1413841284_thumb.jpegpost-60275-0-75106500-1413841354_thumb.jpeg
Crazy front wheel track.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
