Hi All
I believe the time has come to part with my car. I don't really want to, but opportunities lie ahead so I have to let it go.
S1 R33 GTST.
Driveline:
LS2, removed from 2006 VE HSV, Engine has been left un modified. ( I can supply nitrous cam and nitrous kit for additional.)
Custom made one off headers, 4 into 1 1 7/8 primary stepped to 2 inch finishing in a 3 and half inch collector. The rest of the system is a dual 3 inch, stainless high flow cats, dual hot dogs in the center and finishing through a Varex muffler.
Trans is a fresh built 4L65e
Casings have been machined to suit larger bearings
New band ( almost twice the size of standard )
New servos
New zpak clutches , 13 clutches for each gear
New sun gear
New plenatrys
New oil pump
New valve body's
Converter will be standered for now.
1 piece custom tail shaft,
tail shaft loop
Nissan lock diff
solid mounted rear cradle
solid mounted engine mounts
trans cooler,
pwr steering cooler
engine oil cooler, ( not connected at present)
B&M pro rachet shifter
launch control
D2 suspension
Adjustable caster rods
programmable trans computer
power sterring, ( rach has not been moved from factory location.
New tyres.
Interior:
Mostly stock with the addition of the shifter, Haltech Dash, 6 point bolt in cage. ( Car currently has one aftermarket seat and harness, but these will be replaced with stock seat belts and seats.
The Air con has not been hooked back up, a;though the addition of custom air con lines will allow this to work.
All electrics work.
The drive-line was built with drag racing in mind, however the suspension has been set up for drifting, the currently wheel alignment is tuned for street use.
It is currently un-registered but can supply additional rego at buyers cost. The car was mostly built with legality in mind. You can legally put a 7 liter in this car. Engineering of this wont be hard, Remove front cage bars, and insert rubber between engine mount and cross member, and your 99% there.
Body:
Chameleon on color, ( Kabril Fantasy) by Glaseruit
Front bar is the only let down with chips etc. I do have a new front bar for it, its not painted, however for additional I can paint this bar and fit. Or I can give you the opportunity to purchase spare color of me to paint the bar. ( this color been Glaseruit allows you to pain edge to edge).
The car has NOT been cut to do this conversion. If you wanted you could go back to RB easily
If you have any questions please do not hesitate to ask. I am yet to drive this car. I will be fitting new transmission this week and then testing the car. If I take a little time to respond, please bear in mind, My work does not make it easy to respond during the day however I will do my best to respond as quickly as possible.
Email me at
or you can PM me on this forum.
Please I am not interested in swaps, I don't need another car. I am looking in the ball park of roughly $18.000. I am negotiable, I can also up or down spec the car as required witch can either raise or lower the price.
Edited by Venom8.0
https://www.sau.com.au/forums/topic/421487-r33-gtst-ls2/
