Hey Guys,
been having a misfring problem so decided to rip out the plugs. ECU is not giving any codes so I'm pretty strongly thinking its them.
I've got NGK Iridum's BCPR6EIX-11 which I was told by the mechanic who put them in are gapped to .8mm. ( I need to get a feeler I know)
In the pics, The one from cyc 1 is black (fouled?), the rest look fine so should I replace them all with coppers and gap to .8mm or replace the 1st one only?
Any suggestions would be great, thanks!
Yepp, no.1 is a bit fouled, you should be able to buy just one and replace it cause the others look pretty good.
While the plugs are out, run a compression test if you can, see what the deal is with no. 1.
Also make sure they are gapped down to .8mm... Oh, and clean up the end of the plug where it connects onto the coil thingy (up top), maybe give it a light sand to give it a clean surface to transmit the electricity through.
J
Jay your a champion!! Thanks for helping me out again!
BTW ran through the ecu codes with the other lack of low down power and came up with code 13. Water temp sensor. Has now been replaced and car 'seems' to have picked up some mid range. Maybe the fault retarted timing or something? Dyno run soon will see.
Thanks again mate, I'll head out now and get a replacement and a feeler.
Cheers!
Well I ended up getting coppers (BCPR6ES) because A) no-where I went had them in stock without ordering them in next week and B) the gap on the current ones was 1.1m, and as you guys said gapping them isn't a good idea unless you want to break them.
I gapped them to .8mm and after taking my car for a hard 10min run on ~11psi (in like 7c ambient temp) I'm happy to say the misfiring has dissapeared when before it would have been chronic.
Thanks for the help!
maxim
what is you vehicle ??
because if it is a series 1 rb25det they have weak coils in them and sometime when they are trying to fire iridium spark plugs they dont work to well because of the lower grade coil.
if it is a series2 rb25det then you should have no problems running iridium plugs..
get some carby cleaner and give the coils a good clean with the cleaner , outside and up inside where the plug contacts the spring of the coil..
if you have something different then ignore the different series of coils info..
Hey Sato,
It's actually a 180sx with an series 1 rb25det conversion. I've got Splitfire coils which apparently are pretty good.
After I changed and gapped the new copper plugs seems to be running fine apart from some heitation on cold starts. Running 11psi on a cold (Canberra) night seems to be fine too.
I will clean the coils however as when I was looking at them seemed as if they had been in there for 100 years!
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
