Hi,
I have just bought a wing for my skyline R34 and had it sprayed.
I am about to get it attached and noticed the rubber seal around the feet dont go all the way around.
I have attached a picture, As you can see the top and bottom dont have the rubber, should the seal go all the way around?
http://i1327.photobucket.com/albums/u667/Exodus_AU/Wing_zpsc81b99ad.jpg
Edited by Exodus01
https://www.sau.com.au/forums/topic/421515-r34-wing/
Don't worry about it. It's normal. that doesn't create the seal. OEM comes with a foamy double sided tape that seals the holes from moisture. Don't use anything that will stick the wing down or you will have a mission of it getting it out. I warped my boot lid taking my OEM fitted lid off.
Go to Clark Rubber and buy yourself a sheet of 3mm Neoprene foam. Relatively cheap and is sticky on one side. Stick the side up onto the wing stands and then just bolt on. It also prevents it from rattling as you drive over bumps etc.
https://www.sau.com.au/forums/topic/421515-r34-wing/#findComment-6781644
    • Modern oils are amazing. Add tyres to that as well.
    • Probably a smart choice to buy one vs build, purely for the motivation part as you said! Imagine the metal dust everywhere from grinding all the steel to build one. Ha ha ha!   Also, post a photo of your garage.   Mine is below, this is where I've been cleaning and have already half filled a caged 6*4 trailer. And this is after my cleaning expedition mentioned previously... The middle normally has a car in it, but I'm dumping things in the middle as I sort through them. And poor skyline was dusty and has had the lightest few drops of rain and now it looks atrocious and needs to be dragged back out and washed thoroughly! And yes to the right is technically another bay, you really can only see 2 bays out of 3 in this picture.
    • It's more like on average the things I see a lot of things going wrong. Yes, usually the people who reach out are the ones who are having problems but on average it feels like mechanics and tuners here aren't really competent. I swing between thinking my standards are just way too high and wondering whether people really are just this dumb. I just had the strangest 10+ reply argument on a Facebook group over someone insisting that the factory R34 GTT boost control solenoid reduces boost pressure to 5 psi when it's on and raises boost pressure to 7 psi when it's off despite showing the exact plumbing in the factory service manual and the solenoid behavior detailed in the FSM.
    • I steam cleaned my near new set of volk gtc wheels 14 years ago and farrkkked them lol. The clear coat cracked like spider webbing in several areas. Lesson learnt don't do that. 😭
    • If you don't touch the CAS, then you're fine.
