Yes i know it's not for NSW, but will be paying close attention as the same rules apply here.
You have 20days after rego expires to renew, and when you do it backdates back to the date it expired, yet i "think" if you drive during that period you get fined for being unregistered. Not to mention you get gouged for fees during which you're not supposed to be driving the vehicle.
THE STATE'S car registration system is being investigated amid concerns it may be operating illegally. If that is the case, thousands of car owners could claim compensation for being charged fees for periods during which their vehicle was not officially registered.
At present, if a motorist renews a registration up to 90 days after it has expired, the new registration applies from the original expiry date - not the date on which it was paid, unless a $15 fee is applied.
The state Attorney-General has asked the Crown Solicitor's Office to determine whether this was within the law.
The investigation was sparked by motorist John Staszynski, 66, after he was fined $375 late last year for driving his vehicle two weeks after the registration had expired.
When Mr Staszynski renewed his registration for three months he was told the registered period applied from the expiry of his old registration - which included the time he was driving unregistered.
"I was effectively receiving a registration period of two weeks less than I had paid," Mr Staszynski said.
"It seemed they wanted it both ways - to fine me for being unregistered then retrospectively charge registration for that same period."
The Clearview resident said he first challenged the matter in the Magistrates' Court where he was fined only $100 because the magistrate couldn't determine if the Transport Department was within its rights to apply a renewal retrospectively.
Mr Staszynski then wrote to his local MP, Attorney-General John Rau.
Mr Rau referred the legality of the actions to the Crown Solicitor's Office and said that he was awaiting its advice.
Law Society of SA president John White said if the advice went against the department "the potential is, there might be some money that's been paid (by motorists) that should be repaid".
http://www.news.com.au/money/cost-of-living/south-australias-rego-system-being-investigated-for-illegalities/story-fnagkbpv-1226596004473
https://www.sau.com.au/forums/topic/421560-sa-rego-system-investigated/
Yes, I agree Bobbeh that anomalies exist.
Take CTP. If your Rego is a week overdue, it would mean that your CTP cover is overdue by the same period. So if you maim someone during that overdue period, it can be liability time.
The system & timing yes, is stacked against the vehicle owner. If he has a weekend car and intends to just leave it garaged for say 3 weeks after registration is due; he can't take advantage of that interim period and have his registration validated from the time of payment.
Very interesting,
In NSW, you actually have 90 days after rego expiriy before you require a blue slip to renew. (I know this cause i renewed mine on day 90 last year after puting my engine in lol)
  • you will get fined for driving after rego expired (unless driving to the nearest mechanic for a rego check)
  • NSW, like SA retroactive charges you for the time your car was meant to be registered. (i.e. mine was due in june last year, i renewed/passed in September, but my rego this year is still due in june)
  • you cannot get a 6 month renewal in NSW if you rego date pases (only 12months)
Edited by wedge_r34gtr
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
