Up for sale is my Pride and Joy Immaculate R34-GTT which I have owned for around 6 years now.
This car has always been 100% reliable entusiast vehicle, regularly serviced and treated like a baby. The car is currently a weekend car and has seen minimal use in the last 2 years. The car is regularly polished and waxed and kept inside a garage. It will be sad to see it go and will be missed dearly. The car is a beautiful example, any genuine buyer who views the vehicle will not be disappointed.
The car produces 265kw at the wheels (Tuned by Jim at Tunehouse), A full timing belt kit (+ all belts) has just been performed by Tunehouse + alot of other service work including a compression test which was done before the larger turbo was installed receipts included). Alot of the parts are high end direct fit Jap items to ensure they fit correctly and are reliable + having a near stock under bonnet appearance so there is never any unwanted attention.
Motor : R34 GTT GCG Ball Bearing Highflow, ARC Return Flow FMIC, Z32 AFM, Deatschworks Hi Flow injectors, Apexi Power FC + Hand Control, Apexi Electronic boost controller, Xforce 3inch Stainless turbo back exhaust with high flow cat, Tomei in tank direct replacement hi flow fuel pump, Silicone intake pipe AFM to Turbo, GFB Stealth FX adjustable BOV, Custom Aluminum radiator cooling panel, Greddy Catch can ,Blitz High flow panel filter ,Splitfire coilpacks, Apexi pod filter kit also included.
Suspension: Greddy Type S Coilovers Greddy EDFC control unit for coilovers (not fitted) Whiteline F + R adjustable swaybars Whiteline subcradle bushes Urethane castor rod bushes Cusco Rear strut brace Interior: Nismo gear knob Genuine Nissan GTR V Spec Aluminium pedals Apexi Turbo timer Clarion head unit (cd/MP3+ USB connector in glovebox) Clarion bluetooth kit Pioneer JDM carrozzeria speakers F+R
Exterior: Nismo Eyelids, Nismo Clear front & side indicators, Starcorp Impul rims 18” Nismo copy front lip
Driveline: Excedy 3 puk ceramic clutch (sprung centre) Genuine C's Short shifter, Custom Urethane gearbox mount
The car has just ticked over 100,000 kms and is priced to sell at:
$19,500
Pm or call me on 0402 219 14(two)
  • 3 weeks later...
    • Has equal chance of cleaning an AFM and f**king an AFM. I think you can work out what happened. When the Hitachi ECU sees the AFM die and goes into the associated limp mode, then it will start and run just fine, because it ignores the AFM and just runs on idle maps that will do what it needs to get it going. But there is no proper load signal, so that's about all it can do. My suggestion? If you don't want to go full aftermaket ECU, then get some R35 GTR AFM cards and some housings to put them in, in the stock location, and Nistune the ECU. Better to do a good upgrade than just replace shitty 40 year old tech with the same 40 year old tech.
    • So my car was recently having trouble starting on initial crank, I would need to feather the gas for it to start up but besides that it would start and run fine. So I clicked the idle air control valve (with throttle body cleaner) and cleaned the MAF sensors (with MAF cleaner). The start up issue was fixed and now the car turns over without the assist of the throttle, but the car is in limp mode and wont rev past 2.5k RPM. From what I understand the IACV would not put the car in limp mode, so I am to believe it is the MAF sensors, but it was running fine before and now I cant get it out of limp mode. I cleaned the MAF made sure the o rings were seated properly. Made sure the cables were plugged in properly, the cables also both read the same voltage. Does anybody know why this is or what could be causing this or how to get it out of limp mode?
    • Ooo I might actually come and bring the kids, however will leave the shit box home and take the daily
    • Thanks. Yeah I realised that there's no way I'd be able to cover the holes with the filler, it would just fall through. Thanks again @GTSBoy!
    • That was the reason I asked. If you were going to be fully bodge spec, then that type of filler is the extreme bodge way to fill a large gap. But seeing as you're going to use glass sheet, I would only use that fibre reinforced filler if there are places that need a "bit more" after you've finished laying in the sheet. Which, ideally, you wouldn't. You might use a blob of it underneath the sheet, if you need to provide some support from under to keep the level of your sheet repair up as high as it needs to be, to minimise the amount of filler you need on top. Even though you're going bodge spec here, using glass instead of metal, the same rules apply wrt not having half inch deep filler on the top of the repair. Thick filler always ends up shitting the bed earlier than thin filler.
