Up for sale is my Pride and Joy Immaculate R34-GTT which I have owned for around 6 years now.
This car has always been 100% reliable entusiast vehicle, regularly serviced and treated like a baby. The car is currently a weekend car and has seen minimal use in the last 2 years. The car is regularly polished and waxed and kept inside a garage. It will be sad to see it go and will be missed dearly. The car is a beautiful example, any genuine buyer who views the vehicle will not be disappointed.
The car produces 265kw at the wheels (Tuned by Jim at Tunehouse), A full timing belt kit (+ all belts) has just been performed by Tunehouse + alot of other service work including a compression test which was done before the larger turbo was installed receipts included). Alot of the parts are high end direct fit Jap items to ensure they fit correctly and are reliable + having a near stock under bonnet appearance so there is never any unwanted attention.
Motor : R34 GTT GCG Ball Bearing Highflow, ARC Return Flow FMIC, Z32 AFM, Deatschworks Hi Flow injectors, Apexi Power FC + Hand Control, Apexi Electronic boost controller, Xforce 3inch Stainless turbo back exhaust with high flow cat, Tomei in tank direct replacement hi flow fuel pump, Silicone intake pipe AFM to Turbo, GFB Stealth FX adjustable BOV, Custom Aluminum radiator cooling panel, Greddy Catch can ,Blitz High flow panel filter ,Splitfire coilpacks, Apexi pod filter kit also included.
Suspension: Greddy Type S Coilovers Greddy EDFC control unit for coilovers (not fitted) Whiteline F + R adjustable swaybars Whiteline subcradle bushes Urethane castor rod bushes Cusco Rear strut brace Interior: Nismo gear knob Genuine Nissan GTR V Spec Aluminium pedals Apexi Turbo timer Clarion head unit (cd/MP3+ USB connector in glovebox) Clarion bluetooth kit Pioneer JDM carrozzeria speakers F+R
Exterior: Nismo Eyelids, Nismo Clear front & side indicators, Starcorp Impul rims 18” Nismo copy front lip
Driveline: Excedy 3 puk ceramic clutch (sprung centre) Genuine C's Short shifter, Custom Urethane gearbox mount
The car has just ticked over 100,000 kms and is priced to sell at:
$19,500
Pm or call me on 0402 219 14(two)
  • 3 weeks later...
    • Yeh... literally every time i jump on a forum, see an instagram post or see an engine bay at a car show, i get an idea and add it to my 'to do' list. So what started off as, hey can u just make a couple of intake hard pipes because my dumbass bought the wrong apexi kit, blew out into a 2 week job including braided brake lines & custom bash kit for the front lip haha.  Getting Luke from A4E engineering to make a full custom exhaust with a controllable aes dump valve so i can actually switch between quiet and loud, because right now its just loud all day every day. Then after that go and get the tune redone flex e85 & 98 as i get bugger all milage from e85, makes going for longer drivers difficult
    • Car looks clean as. You ended up getting quite a bit done 😂  So what's the plan for the exhaust?
    • The only Neo rods that were any different to any other RB25 rods were the DET ones, and they were the same as RB26. Here is a Neo DET rod. O5U part number visible. Here is a post in a thread here on SAU with evidence from someone who has done this before. There are photos in the thread of normal RB25 rods.
    • Sure, but why assume that will be the case forever? And why assume you'll be able to do an oil change to swap back to a stock drain bolt before that happens? And does it even matter when I change the oil at fairly short intervals? Life can be funny sometimes and unexpected things can happen. Like breaking a collarbone so you can't do any work on your car for a few months but the oil change is due so you have to take it to somewhere and hope they don't do something stupid like stacking the new drain plug washer on top of the old one.
    • Do u know how to identify the rods are rb25 or neo ones? Can u look into the pics and tell me is they de or de neo ones. Its confusing becoz my motor has de neo head but block is 25de 75t, so really confusing me about rods, crank.
