Hey guys,
Got a set of 17inch gmax drift 6's, 8 inch front, 9 inch rear, which are currently off the car, the tyres, and have been sanded, fixed, and nearly ready to be painted. I was just going to paint them the same colour, but seeing as of late ive been going for a black and white theme to my car, im thinking of painting the rims a black, rather than gun metal again.
Was just wondering what other people thought, and would like some opinions or ideas of other colours that may suit. Am also in the market for some black wheel nuts.
Heres a few pictures.
If someone could photoshop the rims black/a few other colours that would be much appreciated :)
https://www.sau.com.au/forums/topic/421575-what-colour-to-paint-my-rims/
I think ive decided on black but need suggestions on what finish to go. Ie matte? gloss? metallic?
If someone has the photoshop skills :P would appreciate the help as it would mean i could visualise :)
thanks
hrmmm... the thing is i was tossing up between gun metal or black, so i do want to keep it a darker colour. Thanks for your opinion though. And yes, the pics arent the best lighting-wise
Yes, my car isn't a R33, but it's still the same QM1 white paint; so....
* I wanted a genuine Nissan or Nismo colour
* This colour rim is called Nismo Black
* It's satin in texture (rather than gloss or matte)
* The rims were powder-coated with a resin that resists dust accumulation
* The job was done by Craved Coatings in Penrith
* Black wheels on white paint can affect colour balance in photographs (as in my top photo)
* Fill-in flash though creates a very nice effect as shown by Matt Everingham (as in the bottom photo)
It's still possible to get Nismo wheel nuts. They can scratch easily - and it shows.
Black RAYS Duralumin nuts are matte in texture. They still cost a lot.
But 'copies' of those Duralumin nuts can be obtained on eBay probably at about $60 a set (including lock nuts).
Genuine Duralumins or copies must not be tightened beyond 110Nm
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
