Hey guys,
Got a set of 17inch gmax drift 6's, 8 inch front, 9 inch rear, which are currently off the car, the tyres, and have been sanded, fixed, and nearly ready to be painted. I was just going to paint them the same colour, but seeing as of late ive been going for a black and white theme to my car, im thinking of painting the rims a black, rather than gun metal again.
Was just wondering what other people thought, and would like some opinions or ideas of other colours that may suit. Am also in the market for some black wheel nuts.
Heres a few pictures.
If someone could photoshop the rims black/a few other colours that would be much appreciated :)
https://www.sau.com.au/forums/topic/421575-what-colour-to-paint-my-rims/
I think ive decided on black but need suggestions on what finish to go. Ie matte? gloss? metallic?
If someone has the photoshop skills :P would appreciate the help as it would mean i could visualise :)
thanks
hrmmm... the thing is i was tossing up between gun metal or black, so i do want to keep it a darker colour. Thanks for your opinion though. And yes, the pics arent the best lighting-wise
Yes, my car isn't a R33, but it's still the same QM1 white paint; so....
* I wanted a genuine Nissan or Nismo colour
* This colour rim is called Nismo Black
* It's satin in texture (rather than gloss or matte)
* The rims were powder-coated with a resin that resists dust accumulation
* The job was done by Craved Coatings in Penrith
* Black wheels on white paint can affect colour balance in photographs (as in my top photo)
* Fill-in flash though creates a very nice effect as shown by Matt Everingham (as in the bottom photo)
It's still possible to get Nismo wheel nuts. They can scratch easily - and it shows.
Black RAYS Duralumin nuts are matte in texture. They still cost a lot.
But 'copies' of those Duralumin nuts can be obtained on eBay probably at about $60 a set (including lock nuts).
Genuine Duralumins or copies must not be tightened beyond 110Nm
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
