  • Replies 42
Go to driver's side strut tower, locate the boost solenoid (small tube looking thing), pull the whose off with a white band on it, squish it, it should feel hard (piece of plastic in there), cut that bit off (so you remove the white band/plastic restricter thing), put the hose back on, enjoy 12psi.
Without knowing the condition of the 20 year old standard turbos, I wouldn't suggest anything over 12 psi unless you WANT to blow the turbos. Keep it sensible until you are ready to upgrade them.
Stock boost for the R32 GTR is around 0.7 Bar = 10.9 Psi.
Well that's what mine ran at.
If you don't know the condition of the stock turbos don't run anything above 0.8 Bar = 12 Psi.
thanks mate only one who gave me a straight answer haha cheers
​Just in regards to your bigger front mount intercooler, you were better off spending the money on Down and Front Pipes with a High Flow Cat.
Giving your GTR a full exhaust upgrade will benefit you more at this stage, if you just want to keep it stock-ish...
Stock GTR front mount intercooler can handle 300+ kW's.
But anyway, all for the better in the long run.
Sorry to butt in. On the subject of stock engine and boost, I'm running a very healthy R33 Rb in my 32-r and I'll upgrade to N1 steal wheels with ceramic coatING on the hot side, what's a good boost for me while still being on the safe side?
Sent from my SC-03D
What N1 turbos you getting?
From memory they came from factory running about 1 Bar = 14.7 Psi.
(R32 GTR Nismo & N1 / R33 GTR N1 / R34 GTR V-Spec N1 & V-Spec II N1 / V-Spec II Nur / M-Spec Nur)
You could run a tad higher 1.1 Bar = 15.9 Psi / 1.2 Bar = 17.4 Psi.
My GTR has the R33 N1s and I have been running 22psi on them for the last 2 years on E85. I think I have stock bottom end. I don't drive it at that boost all day if that helps
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
