selling a petersen external wet sump single stage pump with aluminium bracket to mount on passenger side of block, drive pulley and adapter for the front of a balancer, ross balancer (included) and it even includes the belt.
this is a complete package, all you need is a pick up on your sump and off you go. will not break this pump can send pics of setup
Melbourne
$1200
0411370561
