Was a little lighter on the back/legs last night as I've got shed work to do this week.
Still not managing my 8th rep on the bench, though am doing 7 easier and making a point of doing halves a couple halves after that rep to try and build up some more power for 8. The other way would be upping the weight which is usually what I do and after a week or 2 you're doing 7 reps on the final set of the new weight and can do 8 reps on the previous weight easily enough, but I'm not looking to add heaps of bench weight.
Added a little to the chins and made 7 on the final.
Did not plank or row as I knew I had to start digging and my back hasn't been great as it is.
So after a quick 35min session, spent another 90mins doing this, it has to be at least 300 deep.
3m down, another 9m or so to go...
Finished the main trench last night, that was my cardio, sweated my guts out. Took another 2+hrs to do the remaining 7 or so meters. Now just have another 3 or so to go to connect this trench to the main pit.
Fun times. Back is getting a caning. I've made a point of upping my protein shakes and making sure I'm getting enough creatine, I swear I'm recovering from these digs far better than I expected.
That pipe in the trench is to allow water to flow from front to back as that's the low side of the block. Pit up the front and larger pit in the rear that will eventually take overflow from a water tank.
Once that trench is filled in it'll be concreted over and a spoon drain will sit on top so no mowing or maintenance for me.
I could have just relied on the spoon drain to carry water to the pit at the back and not bothered with the pit at the front and the pipe, but given there's a bit of a dip up in the front corner and my apron will be there I didn't want any water saturating that area so made the call to put a pit in and pipe it to the back to pull water away quickly.
Edited by ActionDan
That's pretty hardcore to be doing on your own!
Surprisingly, the ground is much softer than I expected. I can grab my spade, line it up, put my body weight on it with a bit of a lunge and it'll almost go down the depth of the spade.
I bought a mattock in anticipation (and already had a sledgehammer), but have only needed each a few times where concrete had overflowed the box work etc.
It's gotta be done before the weekend so the concreters can put the spoon drain in and do the apron. Digging the tree hole and relocating that tree you see up front will be fun too.
Skipped Gym tonight, had a bit to do on the shed etc.
Finished my pipe work then dug a 500mm+ deep, 6-700 wide hole to relocate a tree, the ground was so bloody hard.
Surprisingly my shoulders/back etc are OK, but my poor girly IT hands are suffering.
The dog was pretty keen to get in the hole and probably dug another few mm down for me lol
ITT: nothing gym related lol
you should have told me you were digging up your yard, I could have sent the Husky down to help
bitch wont stop digging my yard up
girly hands can be fixed by urinating on them................... just saying
I had gloves one. I always do. And I was only doing 2-3 hour stints each night tops.
I just have girly hands. From all my gym glove wearing and IT working, and glove wearing when working on cars.
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
