  • 3 months later...
I'm still here and still staying active.
A few months of cold and flue (son of rajab having kids brings some germs into the house) has seen me drop a good 4-5kg, so I'm down around 84kg now. The plus side is abs look great and Kate much prefers it so it's not all negatives.
As for exercising, taking it very ginger because sleep, health, and eating do not support anything magical. 90sec break for first 2 second set, 120 sec from 2nd to 3rd set.
Bench 105kg 8/8/7
Squats 20reps at 48kg - I work up to 25/30reps or so then add a little weight.
3min front plank.
Weighted chins at 24kg, 8/8/8
3min Back plank
Weighted dips at 27.5kg 8/8/8
Usually a little toe touching stretching, sometimes a set of 10 rack pulls but I do that only if my back can support it.
Sessions are 35mins tops, but at the moment that's all the time I've got and I'm doing them after all the evening ritual so sometimes 9:30 or so, not ideal but better than getting fat.
Leesh congrats on your results at the comp, great stuff - DL'ing as much as I was at almost 30kg less lol
Edited by ActionDan
I get gains out of my 40 min x 4 sessions. It's amazing how little you actually need to do if you broach it smartly. Compared to my 90 minute sessions once upon a time, hah!
Agreed, I could make a small change and be back on the gains wagon easily I think, there's no pushing for that at that moment though, being able to get into the Gym regularly and stay in shape is enough.
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
