Was a little lighter on the back/legs last night as I've got shed work to do this week.
Still not managing my 8th rep on the bench, though am doing 7 easier and making a point of doing halves a couple halves after that rep to try and build up some more power for 8. The other way would be upping the weight which is usually what I do and after a week or 2 you're doing 7 reps on the final set of the new weight and can do 8 reps on the previous weight easily enough, but I'm not looking to add heaps of bench weight.
Added a little to the chins and made 7 on the final.
Did not plank or row as I knew I had to start digging and my back hasn't been great as it is.
So after a quick 35min session, spent another 90mins doing this, it has to be at least 300 deep.
3m down, another 9m or so to go...
Finished the main trench last night, that was my cardio, sweated my guts out. Took another 2+hrs to do the remaining 7 or so meters. Now just have another 3 or so to go to connect this trench to the main pit.
Fun times. Back is getting a caning. I've made a point of upping my protein shakes and making sure I'm getting enough creatine, I swear I'm recovering from these digs far better than I expected.
That pipe in the trench is to allow water to flow from front to back as that's the low side of the block. Pit up the front and larger pit in the rear that will eventually take overflow from a water tank.
Once that trench is filled in it'll be concreted over and a spoon drain will sit on top so no mowing or maintenance for me.
I could have just relied on the spoon drain to carry water to the pit at the back and not bothered with the pit at the front and the pipe, but given there's a bit of a dip up in the front corner and my apron will be there I didn't want any water saturating that area so made the call to put a pit in and pipe it to the back to pull water away quickly.
Edited by ActionDan
That's pretty hardcore to be doing on your own!
Surprisingly, the ground is much softer than I expected. I can grab my spade, line it up, put my body weight on it with a bit of a lunge and it'll almost go down the depth of the spade.
I bought a mattock in anticipation (and already had a sledgehammer), but have only needed each a few times where concrete had overflowed the box work etc.
It's gotta be done before the weekend so the concreters can put the spoon drain in and do the apron. Digging the tree hole and relocating that tree you see up front will be fun too.
Skipped Gym tonight, had a bit to do on the shed etc.
Finished my pipe work then dug a 500mm+ deep, 6-700 wide hole to relocate a tree, the ground was so bloody hard.
Surprisingly my shoulders/back etc are OK, but my poor girly IT hands are suffering.
The dog was pretty keen to get in the hole and probably dug another few mm down for me lol
ITT: nothing gym related lol
you should have told me you were digging up your yard, I could have sent the Husky down to help
bitch wont stop digging my yard up
girly hands can be fixed by urinating on them................... just saying
I had gloves one. I always do. And I was only doing 2-3 hour stints each night tops.
I just have girly hands. From all my gym glove wearing and IT working, and glove wearing when working on cars.
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
    • Regardless of neglect or incompetence, fixing either is tedious and annoying. Most of the neglect on my car is definitely rust. I hope I can at least pass inspections later on and they won't fail the car due to slightly corroded hardlines. I was generous with rust converter and wax and it looks ok, most lines in the rear are hard to see properly anyways.  Definitely will test them though to make sure they don't rupture under pressure, in that case the car isn't going anywhere this year.
