Hello all,
Just wanted some input on my tune...
Back in 2008 I had my car tuned with HKS2530 @ 15psi & ARC sidemount intercooler
The results shown below: 207.9kw @ 11.5afr
Just recently had my car retuned with HKS2530 @ 19psi, retarded exhaust cam by 8degrees & Apexi Front mount intercooler
The result shown below: 207.8kw @ 11.5afr
Both tunes conducted on the same dyno / mechanic??
Could anyone help explain why there was no power gain when increasing boost? Does it look like a restricted intake / exhaust? or does the turbo top out at 15psi?
Ive found some quick info on the turbo...
HKS GT2530: uses compressor of T3 63 trim, flows a little more but slightly less efficient than the T3 60 trim.
Compressor Map:
30LB/Min or 434cfm @ 2PR @ 65% efficiency.
32LB/Min or 463cfm max flow @ 16psi.
28psi max boost limited by compressor wheel speed.
Thanks for the help :)
  • Replies 50
to be fair it has made the power earlier throughout the entire midrange though...it seems up a little everywhere...adding more boost will often add more to midrange power, but no effect top end too much. depending on the turbo of course but you can put 2 bar through it and it might not make more power but it will pick up a little in the midrange....if you notice your 207kws is in some 300rpm sooner..
basically if you want more power get a bigger turbo or fill the tank with e85, but I imagine from looking at that chart the car is faster now than it was before regardless of the peak power output ;)
**looks like your old ARC cooler was doing a perfectly good job too
How is the boost controlled?
The boost curve is much nicer in the first graph Nice and flat with slow creap!
The second graph looks nice but the falls away too early for my liking so as menchioned only running about 16psi in the top end!
Maybe the exhaust cam has been retarded too far? Causing it to be really strong in midrange but fall over too early! Maybe 6deg and if you could hold the Higher boost too the red line that power figure would grow?
But as said the second tune would have more useable power!
(I am not a tuner just my personal opinion!)
Thanks for the comments.
First tune was using a bleed valve on stock actuator.
Second tune is an adjustable actuator.
The car does feel much faster. However boost is hitting 19psi without much power increase but has all the risks involved in running higher boost?
Tuner reckons intake pipe could be restricting flow, although hasn't been proven yet.
Surprised how well the arc sidemount did. (Could have kept my foglights & auto front spoiler too >_< )
Thanks
What does it matter if there is a power increase ?
if the car is faster you're winning...
edit*
Ok quik browse through rb20 thread shows it should be making around 230-240 yeah..
Yeah was expecting around 220+ hence the worry, else would have stuck to 15psi and sidemount.
Also found it interesting how both tunes were identical peak power 4 years apart haha
What are the inlet temps with that sidemount? That 210 alone is impressive in my book for a side mount intercooler. What are the ARC sidemount's dimensions? I'm guessing decently thick but still rather small length and height wise.
Its a big boy but no doubt it would heatsoak after repeated use. An fmic would provide better temperature though.
ARC m105 - 105mm thick
He already has a bigger FMIC compared to the old run.
Sorry my mistake, didn't read properly.
If the intake to the turbo, or the exhaust system aren't restrictions, and it's not the exhaust manifold, then maybe you'd have to have a look towards engine compression & then leakdown test to make sure the engine's healthy?
Not making power per extra psi of pressure sounds more like intake/exhaust restrictions though.
Also what exhaust do you have? 3" all the way? Cat?
Some people don't agree but I install a decat pipe when ever I do exhaust upgrades.
I find the car seems much more rev happy with out them! Assuming the rest of your exhaust is good!
You can get silicone intake pipes for about $60 of eBay might be something to think about?
Filter is it a good brand? And clean? You would be surprised at how much hp you can loose with a dirty one!
These are the things I would check first and then play with the boost until it holds 19psi to redline
its only running 19psi in the mid , theres hardly any change to the boost at the redline, hence you get the same rwkw?
Maybe get an ebc and set it up for 19psi at redline , and add the 3inch steel intake pipe, although im not sure that turbo is happy with much more than a bar is it?
Edited by AngryRBGTX
    • It's something we all have to consider as time marches on. Also consider lifted rally MX5 conversion at that point.
    • I should be fine for a few more years, whilst I do have arthritis I also exercise and do mobility training every day to keep as fit and healthy as I can, military life, which is the actual cause of most of my joint issues, has set daily regimes, which I weirdly enjoy I also train alot smarter now, not really focusing on lots strength or puffy muscles, I'm more focused on maintaining what I have for my future older self, I actually train as much mobility now as I do exercising Check out this "simple" drill I have been doing daily prior to training now for a while now, this has worked wonders in my all round mobility
    • I'd say one thing that may make you sell is the same reason the guy with the hard top roof sold his. He got old, and his back was giving him too much grief stopping him getting in and out... Old guy said he was 73! He looked and sounded younger than 73 to me! Or maybe I'm just aligning with old people more...
    • Already looked at a few prior to getting the MX5, really nice car, had all the mod cons, but I wasn't really sold on the new "look" I did miss my 2017 Limited, and I personally prefer the "look" of the older car over the new model, but, when pondering I kept going back looking at MX5's But it was same same for the new ND's, I wasn't sold on the new "look", especially the RF with its weird roof, which only half goes down, like a targa top sort of thing As I stated before, I did look at NC's, but the cars I looked at were PRHT's, but I didn't like their roof line "look" of the PRHT, until I saw the soft top version, (someone on SAU posted a for sale ad for one with a soft top that caught my attention, you can blame them for my choice.....🤣) and.... that old style detachable hard tops were available for them, which keeps the old MX5 more smoother flowing roof line, and the more rounded body style, similar to the NA-NB, to me, the arse end of the ND looks to "modern" Much like how I prefer the NC1 front bar, over the later models How long will I keep this car for is unknown, but currently, there's nothing else out there that "floats my boat" for a small, fun, little "sports car", that I can play with and enjoy looking at and driving But, who knows what the future holds, and going off current new car styling, if I replace it, it will be a older model something something
    • looking forward to your t56 swap man its a game changer if it works!
