Hello all,
Just wanted some input on my tune...
Back in 2008 I had my car tuned with HKS2530 @ 15psi & ARC sidemount intercooler
The results shown below: 207.9kw @ 11.5afr
Just recently had my car retuned with HKS2530 @ 19psi, retarded exhaust cam by 8degrees & Apexi Front mount intercooler
The result shown below: 207.8kw @ 11.5afr
Both tunes conducted on the same dyno / mechanic??
Could anyone help explain why there was no power gain when increasing boost? Does it look like a restricted intake / exhaust? or does the turbo top out at 15psi?
Ive found some quick info on the turbo...
HKS GT2530: uses compressor of T3 63 trim, flows a little more but slightly less efficient than the T3 60 trim.
Compressor Map:
30LB/Min or 434cfm @ 2PR @ 65% efficiency.
32LB/Min or 463cfm max flow @ 16psi.
28psi max boost limited by compressor wheel speed.
Thanks for the help :)
  • Replies 50
to be fair it has made the power earlier throughout the entire midrange though...it seems up a little everywhere...adding more boost will often add more to midrange power, but no effect top end too much. depending on the turbo of course but you can put 2 bar through it and it might not make more power but it will pick up a little in the midrange....if you notice your 207kws is in some 300rpm sooner..
basically if you want more power get a bigger turbo or fill the tank with e85, but I imagine from looking at that chart the car is faster now than it was before regardless of the peak power output ;)
**looks like your old ARC cooler was doing a perfectly good job too
How is the boost controlled?
The boost curve is much nicer in the first graph Nice and flat with slow creap!
The second graph looks nice but the falls away too early for my liking so as menchioned only running about 16psi in the top end!
Maybe the exhaust cam has been retarded too far? Causing it to be really strong in midrange but fall over too early! Maybe 6deg and if you could hold the Higher boost too the red line that power figure would grow?
But as said the second tune would have more useable power!
(I am not a tuner just my personal opinion!)
Thanks for the comments.
First tune was using a bleed valve on stock actuator.
Second tune is an adjustable actuator.
The car does feel much faster. However boost is hitting 19psi without much power increase but has all the risks involved in running higher boost?
Tuner reckons intake pipe could be restricting flow, although hasn't been proven yet.
Surprised how well the arc sidemount did. (Could have kept my foglights & auto front spoiler too >_< )
Thanks
What does it matter if there is a power increase ?
if the car is faster you're winning...
edit*
Ok quik browse through rb20 thread shows it should be making around 230-240 yeah..
Yeah was expecting around 220+ hence the worry, else would have stuck to 15psi and sidemount.
Also found it interesting how both tunes were identical peak power 4 years apart haha
What are the inlet temps with that sidemount? That 210 alone is impressive in my book for a side mount intercooler. What are the ARC sidemount's dimensions? I'm guessing decently thick but still rather small length and height wise.
Its a big boy but no doubt it would heatsoak after repeated use. An fmic would provide better temperature though.
ARC m105 - 105mm thick
He already has a bigger FMIC compared to the old run.
Sorry my mistake, didn't read properly.
If the intake to the turbo, or the exhaust system aren't restrictions, and it's not the exhaust manifold, then maybe you'd have to have a look towards engine compression & then leakdown test to make sure the engine's healthy?
Not making power per extra psi of pressure sounds more like intake/exhaust restrictions though.
Also what exhaust do you have? 3" all the way? Cat?
Some people don't agree but I install a decat pipe when ever I do exhaust upgrades.
I find the car seems much more rev happy with out them! Assuming the rest of your exhaust is good!
You can get silicone intake pipes for about $60 of eBay might be something to think about?
Filter is it a good brand? And clean? You would be surprised at how much hp you can loose with a dirty one!
These are the things I would check first and then play with the boost until it holds 19psi to redline
its only running 19psi in the mid , theres hardly any change to the boost at the redline, hence you get the same rwkw?
Maybe get an ebc and set it up for 19psi at redline , and add the 3inch steel intake pipe, although im not sure that turbo is happy with much more than a bar is it?
Edited by AngryRBGTX
    • The powder coating came in at $250 EACH. The TRX rims got a coat of clearcoat on the outside only.
    • Bit wet, but YUMMY
    • Keeping in mind that I am currently getting flat 10 L/100km on my RB25DET, which means >>500km/tank. I would test this car for vacuum leaks, check codes and AFM signal with NissDataScan as D says, check plugs, do a compression check while they are out.
    • It is hard to be specific half way across the world...but it *seems* like it might have a minor issue. Is the idle stable and does it rev smoothly? I would not expect any pops out of what I am assuming is a standard ECU, standard tune, standard exhaust. You can use Nissan Data Scan to find out exactly what is happening when it runs, the cable/software is reasonably affordable if you are not planning on changing the ECU (which hopefully you are not with an NA skyline) BTW your mileage may not be that far off, these are heavy old tech cars, and being NA might mean you use a heavy foot to keep up with traffic....
    • Hey guys! Y'all are the masters so figured I'd check in on a few items here. - My engine sounds ever-so-slightly more raspy than the other NA RB25s I've listened to. It's barely noticeable but definitely a slightly different sound. - When I back off the throttle at high RPM, I will sometimes get a pop out of the exhaust, assuming this can be diagnosed as misfire. Some history on the car: - Had an exhaust leak in auction sheet but was claimed to be fixed by seller (bought from USA importer).  - Car's coil packs and sparks were replaced when it was sold to me, but unsure on what the gap is and whether the coil packs are correct.  - A prior mechanic had misdiagnosed a pilot or throwout bearing sound as LSPI/detonation. Had played with timing a bit, pops/raspy sound of engine just got worse. Got timing reset. - Had failed emissions a few times. First time went in as is, failed. Second time, replaced cat, still failed, running rich as hell. Third time replaced o2 sensor, passed. Car still smells gassy though. - Timing belt and valve cover gasket also replaced.  - Gas mileage is... low. about 350-400K per tank.  Any idea if I'm having any serious issues here or does this all sound like normal old NA RB stuff and I'm fine to drive it with the pops/slightly raspy engine? If it'll help, I can get drop a video of the sound of the engine.
