its only running 19psi in the mid , theres hardly any change to the boost at the redline, hence you get the same rwkw?
Maybe get an ebc and set it up for 19psi at redline , and add the 3inch steel intake pipe, although im not sure that turbo is happy with much more than a bar is it?
I agree there's barely much variance at the peak power in boost between the two setups.
If you focus on deresticting intake & exhaust, and get the boost steady from midrange through to redline (can be tough on internal wastegate turbos) then you should get a better result.
Or do what Jez said lol
  • Replies 50
What are the inlet temps with that sidemount? That 210 alone is impressive in my book for a side mount intercooler. What are the ARC sidemount's dimensions? I'm guessing decently thick but still rather small length and height wise.
that was the issue last time, AIT were sky high, now it can make that power all day.
it was odd that it would not make power even adjusted cam gears all over the place with no real gains.
Only thing i could pick was intake was rubber and small.
it is also has more mid as it took more mid timing.
This sounds more and more like restrictions. The fact that it's not responding to boost and timing.
I would do as I did, and take the advice of Status and knowledgeable SAU members and go down the well beaten path of getting the engine breathing with proven mods (intake pipe, quality front mount, quality dump pipe, good cat, free flowing cat back) before moving on to more in depth troubleshooting.
What size injectors are you using Chris?
Currently have some Nismo 555cc ones.
Yes there are some exceptions,
But imagine if u had an rb25 :)
Haha I have to imagine a world where I could afford all that first! Surely the better pump and some bigger injectors and I can still get 250!
Also what exhaust do you have? 3" all the way? Cat?
Some people don't agree but I install a decat pipe when ever I do exhaust upgrades.
I find the car seems much more rev happy with out them! Assuming the rest of your exhaust is good!
You can get silicone intake pipes for about $60 of eBay might be something to think about?
Filter is it a good brand? And clean? You would be surprised at how much hp you can loose with a dirty one!
These are the things I would check first and then play with the boost until it holds 19psi to redline
3" all the way with hiflow cat. Will buy new silicon joiners & new air filter on the way (although Trent gave a few runs with lid off to see if filter restricting)
Staying away from any ebc / bleed valve for now...
Rb20's just dont seem to be making power lately. Time for rb25 :)
once (if) the 20 pops, then a 25 will be put in :P
Will modify intake next weekend and will have to pop by for another run!
will do. Will report back once intake is sorted out.
Thanks everyone for the help. Will keep this thread updated with any progress :)
Also have you done the throttle body coolant bypass mod?
It's very easy and can drop your intake temps but a few deg :)
It's one of my favorite mods cost nothing so free power!
Why is it run through the TB stock anyway? Is it emissions or something? I had that mod done on my rb25 180 when I had a plazmaman plenum because I had to, but I thought it must be that way stock for a good reason... :huh:
It helps to prevent icing in the TB in cold weather. Think really cold, like Northern Japan cold. Totally unnecessary in 99% of Australia.
i made about 220wkw on rb20 with the same turbo tho it ran out off steam aswell....your not going to get anymore out of that its too small! ive also maxed a TD06 at 270wkw @ 17psi. Pumped 20psi into and picked up 50wkw in the mid range instantly but lost 2kw top end due to the turbo just not being able to flow up top
exactly what is happening here
exactly and where do you spend most of your driving time...in the midrange or on the limiter....;)
Sorry for the late reply
The coolent in the throttle body is to stop it freezing when in sub zero deg temps!!
I am talking about -10 and colder!!
So it is NOT required in Australia!!
Just for example
The lowest temperature ever observed in Japan was -41 degrees Celsius (-42 degrees Fahrenheit), recorded in Asahikawa in January, 1902.
Keep in mind that the intake temps on a (street aka no ice boxers) turbocharged car are normally between 10 to 20 deg hotter than the air temp (depending on setup)
Different dynos but there are loads of people running 220-240rwkws out of a 2530. I know Russ ran 21psi through his thing and made 23#rwkws for a long time before throwing his RB25 in. He couldnt get it to hold more than something like 16psi at redline as it would not hold boost.
For giggles replace the inlet pipe, blank off BOV and remove cat for tuning and go from there
    • I'm interested if anyone agrees with what you've said, and can give a good reason. Temperature of powder coating should be below any temperature you'd use to alter the wheel structure.  Powder coat typically 200 to 250. Annealing if that's what people are claiming would be occuring, starts at 300, and depending on the alloy, can need even up at 400+.   That's the only part I can think of that could cause an issue that people are believing it's from the rim losing hardness and becoming too soft.
    • Negative probe should be on the cars chassis. Positive on the wire.   Start as said above by unplugging everything (unplug the lights, and switches. Now at the switch, there is a wire from the fuse, to the switch, so out your positive on that terminal. It should read open circuit. If it reads something, especially a stupid low value, the short is somewhere between the fuse and the switch. If that's fine, now put the positive probe on the wire that goes to the headlight (at the switch plug). If it reads stupid low, the fault is from the switch, to the headlight.   Another quick test, is take the whole LED light setup from the left, and plug it into the right side, does it still blow the fuse? If you put the right hand side led light setup on the left hand side wiring, does the left hand side wiring now blow?  If the blowing fuse swaps from right to left doing this, your LED lights are the issue.
    • Anyone know if it's a problem to powder coat forged alloy wheel centers (Rays/Volk GT-C). some say it's bad and can damage the alloy, some say it's not a problem.
    • Hey guys, I'm reviving an old post but I'm finally getting around to working on this now. I removed the battery to get a better look at the wires and i traced the wires from the headlight to the fuse box in the engine bay, but the wiring looks fine? The wiring for the R/H headlight is 3 wires and then is bundled up with the large diameter wire that goes underneath the fuse box. I didn't take it apart yet. I know you said that its a short circuit somewhere between the fuse box and the headlight. But could it be the headlight switch on the dash? Also, i pulled out my multi-meter and set it on the Ohms, but i'm not sure where to put the negative probe and the positive probe.
    • I have a 2 lt in Sydney. It was fitted on a R33 GTR, not used for several years . If you are interested email me on: [email protected] I'm not on this forum much .
