welcome!
putting my daily up for sale.
its a 1968 toyota hilux.
model:rn10
engine:12r(1.6 carby)
trans:4 speed on the tree
single cab, bench seat.
ok, so, bought this, got it to a very good mechanical condition, and now im bored and want another 180sx, or a bike, or to finally get my gtr running.
its the very first of the hilux range.
there are NO power options.
it features 4 wheel drum brakes.
they work very well for what they are.
steering box has been adjusted up.
brake master cylinder anf front wheel cylinders replaced.
wheel bearings adjusted.
clutch slave cylinder replaced.
spark plugs replaced.
points replaced.
gearbox oil changed.
new oil and filter in the engine.
new brake and clutch fluids with the changes.
it has been lowered 2 inchs all round.
currently has volk rays 17x9 wheels.
these will go with the car if not low balled to far.
want it cheaper?
should have a set of 16" falcon steelies thatll fit.
THE PAINT REQUIRES ATTENTION!!!!!
apart from that, great car that starts first time, and goes great.
got 10l/100km on a round trip up the putty rd and back down the freeway, so its pretty good on fuel.
the odometer doesnt work any more, speedo is fine, as is the fuel gauge.
blue slip was done in december, with no issues arising.
rego until december 18, 2013.
ok, lets talk coin...
$3,300 for SAU.
will be advertised else where.
mention this add for that price.
pm me, on here everyday.
call me on 0412 362 six six six
located greater west sydney.
now, some pics....
http://i.imgur.com/9bDXQ7J.jpg
https://www.sau.com.au/forums/topic/421722-1968-toyota-hilux-rn10/
  • 3 weeks later...
    • Ok awesome! I’m not running a aac/iacv (although I do have the r34 iacv but I’m running the heater core loop. I’m running the chase bays booster delete so In that case would I need to block off those posts? So at the moment I need to run from one of the posts to the fpr and then a separate post to the boost controller then to the wastegate? Also I’m assuming that each port has a specific use like the first one farthest to the left would be (for example) manifold to fpr and then second would be to boost controller?
    • I was just going through this on Neil's car (33 gtst). Assuming you are using standard AAC and Cold start valves, you need Post Turbo Pre throttle to Boost Controller (if you have one) then to Turbo Wastegate Pre throttle to AAC input AAC input T piece to Cold start input Cold start output to plenum post throttle AAC Output to plenum post throttle AAC Output to brake booster (needs a 1 way valve) Plenum post throttle to Fuel Pressure Regulator Plenum post throttle to Blow off valve signal Plenum post throttle to Boost controller input (if you have one)
    • I’m trying to figure out the purpose of these fittings. Assuming they’re for coolant but not sure where the lead to. I know the bigger one on the right (which isn’t filled) is the brake booster. If anyone has a photo of a diagram of this intake or has a set of instructions it’d be greatly appreciated
    • How much is that r32? Is that $170k or $1.7m
    • Ahhh! My silly brain was thinking Nissan started selling them straight away, but they waited w or three years didn't they?   Maybe Duncan should build an R35 race car over the V37... There's a cheap yellow one on car sales Duncan, would only need your splash of purple added...
