Created this thread in place of the old thread as I now have more stuff for sale;
________________________________________________________________________________
Part: RB30 block with Nitto 3.2 stroker kit
Condition: Brand spankers
Description:
I have for sale, One RB30 block prepped for twin cam head with a Nitto 3.2 stroker crank, 86.5mm pistons and rods, ARP main studs, ACL Race series Main and Big end bearings
Work done;
Acid bath
Bead blasted
Drilled out oil gallery 'Press In' plugs
Tapped and fitted 'Screw In' plugs
Annular grove main tunnel
Line honed main tunnel with ARP main studs (supplied) to OEM specs
Bored then Torque plate honed to 86.5mm with 11mm ARP studs (not supplied)
Dummy assembled for deck height measurement
Notched bottom of bores to clear stroker rods
Notched oil pick up to oil pump rail to clear stroker rods
Machined top of welsh plug housing on exhaust side
Drilled out oil returns to 10mm
Drilled and tapped for tensioner relocation
Ground sump rail removing 0.004"
Ground water pump/ oil pump surface removing 0.004"
Ground deck of block for '0 deck height'
Ran a tap through every bolt hole
Kerosene bathed
Painted with Flame Proof Primer
Painted with Flame Proof Black
Painted with Flame Proof Clear
Crank will be balanced as well as the Nitto 3.2 pistons & rods to my usual 0 tolerance
Crank will be fitted to block with Clevitte engine assembly lube
Contact Details: Pm me for Number
Asking Price: $9,500 firm or $3,000 without crank pistons and rods
Pick-up/Postage Arrangements: Buyer to organise
Other Comments: all cleaned ready to assemble
Dummy assembling
bored & honed, bores chamfered, decked, tops of welsh plug housiong on
exhaust side machined down, water pump/ oil pump surfaces machined,
tensioner relocated, press in plug replaced with screw in type, all painted
bores are finished with 625 grit stones, suited to chrome moly rings and turbo
deck finished to suit a metal head gasket
Sump face machined parallel to cradle parting face
angular grove in main tunnel to suit rb26 main bearings
line honed with arp main studs to re correct roundness with the
extra torque
Notched bottom of bores to clear Nitto 3.2 kit rods
notched oil pick up to oil pump rib to clear Nitto 3.2 rod bolts
Part: RB26/30
details and pictures of the whole build;
http://www.skylinesaustralia.com/forums/topic/374496-gerg-r31s-na-rb2630de/
Condition: Used
Description: Complete engine as is
Parts;
JE 87mm pistons
Precision H beam rods hand picked for exact lengths
King bearings
Nitto crank collar
N1 Oil pump
N1 water pump
ARP 11mm head studs
1.5mm Nitto MLS Head gasket
Pep pro stainless steel +1mm intake and + 1mmexhaust valves
Bronze guides fitted, reemed, and honed
Supertech single springs & titanium retainers
Seat pressure upped to 85lbs
Camtech 10.77mm/ 0.424" Intake Lift 242° Intake Duration @ 0.050"
Camtech 10.74mm/ 0.4228" Exhaust lift 252° Exhaust Duration @ 0.050"
Spitfire coil packs
Gizmo thermal intake & ITB gaskets
Carbon fibre lower timing cover
Just jap Imitation carbon fibre upper timing cover
Just jap Imitation carbon fibre valley cover
Powerbond OEM replacement harmonic balancer
Adjustable cam gears
Xtreme Light weight flywheel
Nizmo 63.5 degree thermostat
Rear drain and side drain to sump, all braided lines included
Oil cooler/ sandwich plate and braided lines
90amp alternator
RB25 neo power steering pump
Work done;
Acid bathed
Line honed
Knife edged crank
Collar fitted
Grub screwed
Ground big end and mains journals
Torque plate honed to 87mm
Ceramic/ teflon coated pistons
Dummy assembled
Decked block
Notched top of welsh plug housing
Balanced everything without tolerance
Striped head
Acid bathed head and parts
Bead blasted
Wet and dry flow bench ported head
CNC 5 angle intake seats
CNC radius exhaust with 1mm seat
Cut out tops of cam bucket holes to clear bigger cams
Balanced valve train (valves springs buckets shims etc)
Ground head to 53cc's
CC matched every chamber
Dummy Assembled and relocated tensioner
Tappet clearances set to 0.018" intake and 0.015" exhaust (no tolerance)
Currently has a static of 10.75:1 has made 225.6hp @ 8,200rpm no turbo
Heaps more stuff I cant be bothered typing
last leak down test I had 4% cylinders 1-5 and 5% in cylinder 6
220-235psi in compression test
every 3 months (give or take a week) its had new motul oil, ryco oil filter and spark plugs
Many ways to get the comp back down to 9:1 to suit a turbo, or keep it high and use e85
Sold as a complete running motor with complete original rb26 intake plenum, without exhaust manifold or turbo
Contact Details: PM me for number
Asking Price: $8000
Pick-up/Postage Arrangements: buyer to organise
Other Comments: Currently still in car running
after assembly;
when its clean;
Part: VLT- MX7 Manual 5 speed gear box, single piece tail shaft to suit r31 & clutch kit, slave cylinder, and cross member
Condition: used
Description: MX-7 gear box out of a VL turbo
1 piece hardy spicer tail shaft,
heavy duty ceramic 6 puk clutch kit with pressure plate modified that says +1280 (lbs or kg cant remember) throw out bearing needs replacing
Asking Price: $1,800 for the lot
Other Comments: Still in car
Next to the r31 manual bits
Part: Haltech Pro Sport 2000, haltech flying loom, GPS race dash
Condition: Used
Description: Haltech Pro Sport 2000 Computer, Haltech flying loom mixed into and R32 wiring harness, GPS haltech race dash
Contact Details: PM for Number
Asking Price: $4,000
Part: RB26 ITB Ram Tubes
Condition: used
Description: made myself to suit GTR ITB
Contact Details: PM me for Number
Asking Price: $600
Other Comments: still in car
Part: RB26 extractors
Condition: Used
Description: rb26 extractors.... not expecting these to sell quickly
Asking Price: $800
Other Comments: still in car, could be useful for someone on their P's with a rb26 they want to put in
Part: RB30 extractors
Condition: Used
Description: rb30 extractors bead blasted, gathering rust, says "advanced" on them
Asking Price: $70
Other Comments:
  • Like 1
Might be interested in the NA engine. But price seems steep. Pm me your best best price.
At the moment I'm on emails with nitto to order customs pistons for the similar setup.
The nitto 3.2 stuff is priced at cost price
the rb26/30 motor itself has cost me 13,900 (not including tune, intake extractors or exhaust)
The vlt gearbox clutch and tail shaft cost me 2,500
The haltech ps2000, gps dash, r32 wiring and having a professional mix it in with the flying loom cost me 5,200
As far as i am concerned, the prices are quite reasonable, so if you intend to low ball, or try to tell me how much you believe its worth (which is your opinion and not fact) don't expect a reply
(the reason my phone number is not posted)
serious buyers welcome :)
Haltech Platinum Pro2000, Flying loom wired into an R32 RB26 GTR loom with 2 year old coil pack harness is now out of the car, GPS Data Logger Race Pack dash coming out tomorrow
happy to sell the above for $3,500 (or $1,500 for dash and $2,000 for wiring and computer)
rb26/30, to seperate;
rb26 head ill sell for $4,500, everything in the head and everything bolted to it (cams, springs, valves, bronze guides, intake manifold with thermal gaskets injectors, coil packs, covers, drains and lines, ported, cam clearanced, balance valve train, full reco cnc'd seats etc)
rb30 block ill sell for $3000 (pistons, rods, bearings, crank collar, head studs, sump, light weight flywheel, balancer, power steering pump, alternator, carbon fibre lower cover, n1 water pump, n1 oil pump bored honed, decked, crank ground, knife edged balanced, relocated tensioner, notched welsh plug housing etc)
head has 53CC's, you can slap it on a NEO bottom end
or slap it on a block with flat top pistons
the block has pistons with a 10cc dome, chuck a rb25/26 head on with a 64cc chamber probably around 9:1 with a 1.2 head gasket
once again best price is advertised, only those who are genuinely serious about buying (not low balling) the above message me
if there are parts you dont need, the buyer can pull them off to sell themselves, never know buyer could make money back by selling bits they dont want
Has SAU members gone soft or something?!? :no:
I can't believe none of this has been sold yet!
great price bud! I just wish I hadn't bought my internals before you posted this!
Good luck with the sale!
:cheers:
    • Hey, mike has that Rear parcel shelf speaker covers r32 might be applicable to your need. I would advice to email him for pictures if you're still interested. I suggest email him because he his yet to upload pics to the forum which give me assurance that he hasn't sold it..markettrading1002 at aol dot com tell him from daniel
    • Hey, mike has that  R32 gtst front bar-sydneymight be applicable to your need. I would advice to email him for pictures if you're still interested. I suggest email him because he his yet to upload pics to the forum which give me assurance that he hasn't sold it..markettrading1002 at aol dot com tell him from daniel
    • Hey, mike has that noltec r32 front upper  might be applicable to your need. I would advice to email him for pictures if you're still interested. I suggest email him because he his yet to upload pics to the forum which give me assurance that he hasn't sold it..markettrading1002 at aol dot com tell him from daniel
    • Hey, mike has that Rb20det Sydney might be applicable to your need. I would advice to email him for pictures if you're still interested. I suggest email him because he his yet to upload pics to the forum which give me assurance that he hasn't sold it..markettrading1002 at aol dot com tell him from daniel
    • Hey, mike has that R34 GTR rear propshaft - Getrag 6 speed might be applicable to your need. I would advice to email him for pictures if you're still interested. I suggest email him because he his yet to upload pics to the forum which give me assurance that he hasn't sold it..markettrading1002 at aol dot com tell him from daniel
