I don't think SAU members have gone soft, its more there are so many different combinations for the rb, my set up probably won't suit everyone's intentions,
I have had quite alot of interest, majority probably on school holidays, with insulting offers, but those that weren't insulting, were interested but did want a few things removed that they wouldn't need, which i don't have time to be pulling everything down
though the haltech stuff has sold
and the 3.2 stuff has a couple people quite eager (messages every couple days) and all they're waiting on is for the pistons to turn up
To get the rb26/30 compression down with the 53cc dome and 1.5mm thick head gasket
9.4:1 87mm rb26 flat top pistons, grind 0.015" off block, replace 1.5 with 1mm head gasket + e85
9:1 87mm rb26 flat top pistons, grind 0.015" off deck
8.72:1 87mm rb26 flat top pistons
8.51:1 87mm rb26 flat top pistons with 1.8mm head gasket
Simple and easy to lower compression to suit turbo
or keep it at 10.75:1 e85 and up to about 15psi
I'll just put a little encouragement here;
R.I.P.S 8.5 second pass with a nitto 3.2 and a few other bits
http://www.speedhunters.com/2013/05/mgawot-2-a-1500hp-gtr-street-car-that-runs-eights/
For the people low balling you have a real think what all this stuff is worth. Like one member earlier on thought the NA rb26 was steep priced. Yeah right it is. Go get a qoute on building fully ported oversized valved big cammed 26 head with a 5 angle valve job . You'll just get change from 10k. And you get a fully built bottom end with it. Bargain I say. And it's quite simple as stated to drop compression in more than 1 way. Good luck with sale Gerg_R31. Sorry for the rant in your for sale thread. I'm just so sick of people wanting stuff
for nothing.
Cheers josh
Unfortunately that is just part of selling, haven't had a low ball offer since school holidays finished
It will always be what the buyer thinks its worth vs what the seller thinks its worth
i think i should be selling it all for more then its worth, but i did chose the prices based on what i would accept as a minimum
i know it will sell, im just not in a rush or desperate for money
Do you deal with workshops that use engines like this? Might be worth having a chat to a few, time is a big thing with builds and seeing you have an engine ready to go it might look appealing to some of their customers.
Had a few of works customers interested, or their customers, heaps of tyre kickers or it doesn't suit their intentions (fair enough, not going to sell anyone something they can't use)
I do finish up here in 7 weeks, don't really have space for the 3.2 stuff at home
To add ACL race series MLS head gasket sold
hi greg im in the uk ,not sure on what shipping costs to the uk would be.
what is the price for the complete 3.2 bottom enf assembled .
this is just an enquiery but i think this would be a cheaper option for me rater than one
of the rb 30 engine builders in my country and with better parts.
will this block bolt to 4wd r32 gtr gearbox ok ?
i no i need 4wd adaptor plate.
i need a oil pick up and sump as well for 4wd do you have these ?
i tryed private mailing you but for some reason its not working
many thanks adrian
$9,500 crank bolted in rods on pistons
AWD adapter kit http://proengines.com.au/sumpadapter.html
I find that's the easiet kit to use and it comes with all bolts and internal oil pick up
Gear box bolt patterns in the rb series don't change on the block (as far as i am aware)
gerg_r31@hotmail.com email me there if you'd like
Bump
still for sale;
RB30 block with nitto 3.2 stroker crab.k
RB30 block (former RB26/30DE)
RB26 head off block above
VL-T MX7 gear box (with clutch and pressure plate)
Rb26 ACL race series full gasket kit
Rb26 ram tubes to suit ITBs
RB26 extractors
to add;
Bare RB26 head (with all cam caps) light porting, cnc cut seats to suit +1mm valves, tomei bronze guides, full reco'd $1,500 (including chamfered and line honed cam tunnels)
I'll be leaving work in 4 weeks, I will be adding more RB stuff that I've accumulated over my time at work, once all them bits sell im only putting spanners to my own motors
I'll throw in a little sales pitch here :P
NITTO's RB30 Stroker kits
  • 4340 Grade Billet Steel
  • Fully Counter Weighted
  • Undercut Counter Weights
  • Knife Edged
  • Nitrided Finish
  • Fully Balanced
  • CONNECTING RODS
    • I-Beam Construction
    • Quality Oversize 7/16” ARP 2000 Series Bolts
    • Oil Squirter Galleries from Big End
    • Oversize 22mm Little End
  • PISTONS
    • JE / NITTO Produced Quality
    • Forged T6 2816 Alloy
    • Low Silicone Content
    • Contact Reduction Grooves
    • Accumulator Groove
    • Thick Wall 93 Series Nickel / Carbon Steel Alloy Pins
    • JE Pro Seal Premium Ring Se
Increased stroke from 85mm to 90mm which is the peak of stroke increasement for making power efficently
Engine capacity is increased from 3.0Ltr to 3.2Ltr (which provides more power and torque whilst still retaining a strong ability to rev and produce horsepower at high RPM)
Crankshaft is made from solid 4340 billet steel,
4340 one piece forged billet steel I-beam connecting rods and
JE/Nitto forged piston set along with upgraded thick wall gudgeon pins and premium gas treated ring sets.
All components have been meticulously machined to exacting tolerances and the highest standards.
All Nitto stroker kits are far superior and track proven compared to the cheaper manufactured kits currently available that consist of cast crankshafts, and unfinished H-beam connecting rods.
NITTO's RB30 Stroker kits are designed for use in all motorsport classifications including drag racing, drifting and circuit racing. Rotational capability is lifted to 10,000 + RPM and power handling is rated to 1600 HP. The changed harmonics due to the crankshaft material, counter weights and knife edging design, results in a much “freer revving” more balanced engine.
Continuous testing and development on and off the track has allowed us to design a kit with extreme strength whilst retaining a sensible reciprocating mass weight
so there's a perfectly good reason why the nitto 3.2 should be powering your skyrine :D
    • Yep that is correct. It allows you to adjust the short throw range from what I can tell
    • Car has been running great, I've put about 300km's of break in time on it. First thing that stands out with properly sealing rings is no more noticeable crankcase smell coming out of my catch can. This may seem insignificant, but the constant smell while driving around was infuriating. It's also nice to see my oil level remain stable. Two new issues have developed that I only noticed this weekend though. There's a very noticeable driveline vibration past 100kmh. I only noticed it now as I've been babying it under 100kmh in the backroads. This comes as no surprise as I'm running a one-piece shaft, and I paid zero attention to my driveshaft angle when I put everything back in. I also have a fair bit of voltage drop on hot starts. The starter audibly is forcing. No issues on cold start though. I must not have removed all the paint under my main block ground during assembly. I'll try and take care of both those issues this week once the kids are asleep.  I also received all the parts I was missing for my direct port setup. I will hopefully have pictures of that up soon. I'm hoping to get back on the dyno the week of June 30th as I'll be on vacation. I'm confident I should be able to make north of 500rwkw on pump gas and WMI. I'll go back again later this summer with E98, but I want to confirm my ethanol content sensor is working properly first. I've never seen it read anything but 11%. This makes sense for our 10% ethanol content pump gas here, but I would expect the occasional movement between fill ups.
    • 75% complete. Will now need to get a new axle with 5x114.3 hubs and then figure out how to customize some mudguards for it once the wheels are on.
    • Trailer prep is underway... Lined up the wheel to get a rough indication of how it would sit Then removed all the bits (as far as possible) and gave the frame a light sand and quick lick of paint   Then added some carpet
    • okay, so I figured this out, removed needles and reinstalled after swapping the gauge face on my triple gauge for my ER34, all work and look good. I tried to do the same for the main cluster, but the main cluster gauge faces are dished, the replacement gauge face are flat, so due to the dish in the org face ,mounting backing plate (clear) and depth of the needle, the flat gauge face will not work. I notice that R34 gtr gauges are flat, appears to be different clear backing plate that aren't dished. are these available, or what have others done to install flat gauge faces?
