I don't think SAU members have gone soft, its more there are so many different combinations for the rb, my set up probably won't suit everyone's intentions,
I have had quite alot of interest, majority probably on school holidays, with insulting offers, but those that weren't insulting, were interested but did want a few things removed that they wouldn't need, which i don't have time to be pulling everything down
though the haltech stuff has sold
and the 3.2 stuff has a couple people quite eager (messages every couple days) and all they're waiting on is for the pistons to turn up
To get the rb26/30 compression down with the 53cc dome and 1.5mm thick head gasket
9.4:1 87mm rb26 flat top pistons, grind 0.015" off block, replace 1.5 with 1mm head gasket + e85
9:1 87mm rb26 flat top pistons, grind 0.015" off deck
8.72:1 87mm rb26 flat top pistons
8.51:1 87mm rb26 flat top pistons with 1.8mm head gasket
Simple and easy to lower compression to suit turbo
or keep it at 10.75:1 e85 and up to about 15psi
I'll just put a little encouragement here;
R.I.P.S 8.5 second pass with a nitto 3.2 and a few other bits
http://www.speedhunters.com/2013/05/mgawot-2-a-1500hp-gtr-street-car-that-runs-eights/
For the people low balling you have a real think what all this stuff is worth. Like one member earlier on thought the NA rb26 was steep priced. Yeah right it is. Go get a qoute on building fully ported oversized valved big cammed 26 head with a 5 angle valve job . You'll just get change from 10k. And you get a fully built bottom end with it. Bargain I say. And it's quite simple as stated to drop compression in more than 1 way. Good luck with sale Gerg_R31. Sorry for the rant in your for sale thread. I'm just so sick of people wanting stuff
for nothing.
Cheers josh
Unfortunately that is just part of selling, haven't had a low ball offer since school holidays finished
It will always be what the buyer thinks its worth vs what the seller thinks its worth
i think i should be selling it all for more then its worth, but i did chose the prices based on what i would accept as a minimum
i know it will sell, im just not in a rush or desperate for money
Do you deal with workshops that use engines like this? Might be worth having a chat to a few, time is a big thing with builds and seeing you have an engine ready to go it might look appealing to some of their customers.
Had a few of works customers interested, or their customers, heaps of tyre kickers or it doesn't suit their intentions (fair enough, not going to sell anyone something they can't use)
I do finish up here in 7 weeks, don't really have space for the 3.2 stuff at home
To add ACL race series MLS head gasket sold
hi greg im in the uk ,not sure on what shipping costs to the uk would be.
what is the price for the complete 3.2 bottom enf assembled .
this is just an enquiery but i think this would be a cheaper option for me rater than one
of the rb 30 engine builders in my country and with better parts.
will this block bolt to 4wd r32 gtr gearbox ok ?
i no i need 4wd adaptor plate.
i need a oil pick up and sump as well for 4wd do you have these ?
i tryed private mailing you but for some reason its not working
many thanks adrian
$9,500 crank bolted in rods on pistons
AWD adapter kit http://proengines.com.au/sumpadapter.html
I find that's the easiet kit to use and it comes with all bolts and internal oil pick up
Gear box bolt patterns in the rb series don't change on the block (as far as i am aware)
gerg_r31@hotmail.com email me there if you'd like
Bump
still for sale;
RB30 block with nitto 3.2 stroker crab.k
RB30 block (former RB26/30DE)
RB26 head off block above
VL-T MX7 gear box (with clutch and pressure plate)
Rb26 ACL race series full gasket kit
Rb26 ram tubes to suit ITBs
RB26 extractors
to add;
Bare RB26 head (with all cam caps) light porting, cnc cut seats to suit +1mm valves, tomei bronze guides, full reco'd $1,500 (including chamfered and line honed cam tunnels)
I'll be leaving work in 4 weeks, I will be adding more RB stuff that I've accumulated over my time at work, once all them bits sell im only putting spanners to my own motors
I'll throw in a little sales pitch here :P
NITTO's RB30 Stroker kits
  • 4340 Grade Billet Steel
  • Fully Counter Weighted
  • Undercut Counter Weights
  • Knife Edged
  • Nitrided Finish
  • Fully Balanced
  • CONNECTING RODS
    • I-Beam Construction
    • Quality Oversize 7/16” ARP 2000 Series Bolts
    • Oil Squirter Galleries from Big End
    • Oversize 22mm Little End
  • PISTONS
    • JE / NITTO Produced Quality
    • Forged T6 2816 Alloy
    • Low Silicone Content
    • Contact Reduction Grooves
    • Accumulator Groove
    • Thick Wall 93 Series Nickel / Carbon Steel Alloy Pins
    • JE Pro Seal Premium Ring Se
Increased stroke from 85mm to 90mm which is the peak of stroke increasement for making power efficently
Engine capacity is increased from 3.0Ltr to 3.2Ltr (which provides more power and torque whilst still retaining a strong ability to rev and produce horsepower at high RPM)
Crankshaft is made from solid 4340 billet steel,
4340 one piece forged billet steel I-beam connecting rods and
JE/Nitto forged piston set along with upgraded thick wall gudgeon pins and premium gas treated ring sets.
All components have been meticulously machined to exacting tolerances and the highest standards.
All Nitto stroker kits are far superior and track proven compared to the cheaper manufactured kits currently available that consist of cast crankshafts, and unfinished H-beam connecting rods.
NITTO's RB30 Stroker kits are designed for use in all motorsport classifications including drag racing, drifting and circuit racing. Rotational capability is lifted to 10,000 + RPM and power handling is rated to 1600 HP. The changed harmonics due to the crankshaft material, counter weights and knife edging design, results in a much “freer revving” more balanced engine.
Continuous testing and development on and off the track has allowed us to design a kit with extreme strength whilst retaining a sensible reciprocating mass weight
so there's a perfectly good reason why the nitto 3.2 should be powering your skyrine :D
    • Had another look at the car and I noticed the fuel pump isn't priming on ignition. I'd taken out the pump from the boot to siphon out the old fuel, so maybe I've knocked something loose or broken a wire putting things back together. Will go back with a multimeter and try to work out what's stuffed. Kinda hoping it's the pump itself thats gone so I can upgrade it
    • Yeah agreed, you can't assume that shop are they only people who ever had to work on it. It was just a guess on the mods based on how things were done back then. You can check the Air Flow Meters by the part number on their tags, they are likely either Z32 or Nismo ones (both read about the same but the Z32 one is a little larger while nismo is stock size but supports the higher airflow like a Z32). And yes, all that would get you to 450hp / 340kw To tell what is happening with the turbos, you want a photo of the tag on the core, that will say what it was made out of  (they can retain the front and rear covers to make the plumbing easier)
    • I'm selling my personal race car. 1992 BNR32 Skyline GT-R About eight years ago the engine developed the dreaded low oil pressure problem. I removed it and found the issue. However shortly after I moved half way across the country, moved my work shop, bought a house, got married, then moved my shop again to it's permanent location for the time being. in turn I do not have the time to race this car as it should be. In turn the engine I built for this car will end up in my street car and this car I hope finds a home with someone who can use it to it's full potential. The roll bar was built by Jason Noren Fabricaiton in Pomona California to SCCA and NASA Specs. The car used to compete in redline time attack and global time attack enthusiast class. It also has a fire suppression system.  The car is with me at my workshop in Kyle Texas, USA. Shipping it is no problem, I can personally deliver the car to the port of either Houston or Los Angeles. Any other port depending on where it is may require transport but we can always work that out.   The chassis itself is rust free, rear quarters and under fenders are free of any rust so it's a very solid foundation for anyone who wishes to move forward with it. As posted and at the asking price of $20,000 USD the car includes all of the following;   All OEM Body panels, front fenders, rear bumpers etc.  OEM Nissan Projector headlamps (Pictured N1 lamps were removed) OEM Nismo Side Skirts / Extensions OEM Rear Spats  Front & Rear Subframes are installed car is full roller Rear Subframe has Cusco Camber Arms, Whiteline HICAS Elimination Front Subframe has Whiteline tension rods and whiteline Sway bars w/ endlinks.  Buddy Club N1 Coilovers All chassis wiring and engine wiring is in tact. Attessa System is fully in tact and was functional before engine removal.  BCNR33 GT-R Brembo Brakes F+R with Endless MX72 Plus Pads, DBA Rotors & Stainless Steel Brake lines Billion Racing Radiator Billion Radiator Hoses Fluidyne Engine Oil Cooler Accusump System (trunk Mounted) 5 Speed Transmission w/ Transfer Case F+R Prop-shafts Rear Differential With rear Axles.  Nismo Gauge Cluster Nismo Clutch + Flywheel   Essentially what is needed to make this car running and driving again is as follows: A working Engine, an ECU, and time to put it together. The price posted is or best offer as I am willing to remove some components to accommodate price to a certain extent. If any serious buyer wants full detailed pictures, videos, or any questions I'll be happy to answer them. I believe this car is priced to move quickly considering it's a rust free and very straight chassis but always open to fair negotiation.  I can be contacted via phone or email. (+19517081648) email is juan@bardabe.com
    • So...to my (and my mechanics doing the swap) surprise...the oil pan from NEO engine does not fit 100% and needs to by modified like this: It is not a huge problem but in the future i want a "proper" oil pan. So question is...what different oil pan can i get to fit without any problems and modification? Thanks!
    • Some more info I found.  These are the last entries Yoshikiyo Fujii made on his blog before he passed away in 2009: http://blog.livedoor.jp/fujii_dynamics/ And finally this is where the workshop was situated:  https://maps.app.goo.gl/HhTPtHzt3WVcBTiEA
