Some days it will drive for hours with no problem. Other times it will shut of 4-5 times in the space of a minute. There is no warning when this happens and you literally do not know 1 second beforehand. There is a very slight engine stumble sometimes but 99% of the time you cannot regain it even if you floor it, it acts like a kill switch. You can shift to neutral and restart the car. It may drive for hours or switch of 1 second after you restart it.
What I have done so far.
Replaced fuel pump and fuel filter with brand new units
Changed spark plugs and checked coils.
Checked some vacuum lines
Cleaned MAF sensor
CHanged Crank angle sensor (its a the black plastic unit from a R34 with the half moon because its a late series 2 aka series 3)
The car is fitted with both an immoboliser and turbo timer. I suspect these may be a culprit. Any common fault I should check before I pull these out?
The car is a late 1998 R33 gts-t.
https://www.sau.com.au/forums/topic/421766-r33-suddenly-shuts-of-while-driving/
I had a problem like this but it was after i changed my turbo inlet pipe. My MAF was suffering from reversion BIG time cuasing it to spazz out and shut off. I could almost ALWAYS make it shutt off while going up a hill and then pushing in the clutch to let the RPMs drop.
Ok guys after taking out the turbo timer and immoboliser, the problem is still exactly the same, which is a shame because now those units have to go back in and it was all for nothing.
Scotty nm35, The fuel pump is this one http://www.ebay.com.au/itm/Performance-Fuel-Pump-Skyline-RB20-RB25-R32-R33-R34-/120568439688?pt=AU_Car_Parts_Accessories&hash=item1c12706388
The relay used is the same as the stock unit. Only the bracket had to be really modded.
GTR nation, the old fuel pump DID make a whining loud whining noise, the new one does not. Have not monitored fuel pump volatge when this happens. Would need some kind of digital data logger as it may take as long as a day to turn of and you cant keep your eyes glued to the multimeter.
I am going to try a new MAF unit next but its very frustarting. Should have taken firestorms advice but it may end up doing the same thing with a new maf. Guess it was the easiest thing to try first though.
Edited by sonicz
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
