For my 100,000km service i decided to fit all genuine Nissan parts. Can anyone explain why a genuine Nissan oil filter (part No. 15208-53JOA) is only half the size of an aftermarket Ryco (Z145A)? Can't help but think the larger aftermarket filters would perform better than the tiny Nissan filter.
Anyone got any tips on how to change the oil filter without spilling oil everywhere? I usually try making a pool with paper towel and stick it under the filter while i screw it off but still always manage to make a mess.
https://www.sau.com.au/forums/topic/421772-neo-oil-filters/
I shove a folded old towel down below the oil filter and spread it out abit and it generally catches all the mess. Paper towel can be pretty slow at absorbing oil and it will run away easy.
Can't help with the filter sizes though !
https://www.sau.com.au/forums/topic/421772-neo-oil-filters/#findComment-6785714
Nismo filter is allegedly highly efficient although guys here with relocation kits use a variety of filters including a giant aircraft engine filter! But if you change the oil and filter regularly the stock item should suffice.
Re the mess - relocation kit is one solution but in my case I don't really have room to put it anywhere else. Put rags under the filter and when you have loosened the fliter put a plastic bag over it before you take it right off (and try to keep it the right way up as you lift it).
https://www.sau.com.au/forums/topic/421772-neo-oil-filters/#findComment-6786199
    • For a daily just run Akebono ceramic pads. That's what they're optimized for. Obviously don't try to run it on track or anything like that.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
