Complete rb25det head for sale, had 130,00 K . Comes with evrything, exhaust manifold,plenum, cams, injectors cam covers ect.
Looking for quick sale $200 located vic northern suburbs.
Harris 0432 363 101
Hey mate,the motor was removed because of a low compression reading in cylinder no 6 and 2. Pretty sure the cause of the low comp was from cracked rings, as the pressure did jump up once i squirted oil in the cylinders and re tested. The bottem end was bined as it was cheaper to buy a second hand motor than to build. Hope that helps, i knever got the head looked at profecionally but cams didnt look to be scored or anything.
Just to add car was completely standard, factory boost, cooler exhaust ect but my mate did have a bad habit of thrashing it when it was cold, told him it will be the death of it lol.
  • 2 months later...
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
