iv just had my car stolen this morning in melb/coburg and id like it back in one piece.
its a long shot but if anyone sees it please contact me 0401683433.
it has hail damage all over it, not hard to miss. thanks
Edited by rusty31
https://www.sau.com.au/forums/topic/421802-stolen-r32-gtst/
  • 4 weeks later...
rego number?
https://www.sau.com.au/forums/topic/421802-stolen-r32-gtst/#findComment-6813942
