Title says it all, guys. Recently swapped in a Series I Rb25DET, it runs well enough, but I'll be damned if I can't get any of my accessory power to work.
Inoperative items include:
- Gauge Cluster
- Rear lights (Brake, Running, etc)
- Turn Signals (Front and Rear)
- Interior Lights
- Accessories (A/C, heat, power windows, etc)
Items still functioning:
- Headlights
- Radio and Speakers
I'm kind of burnt out and at a complete loss. It's not exactly legal to drive around as it were, so getting these things back would be most appreciated. I figure there is a sole cause for pretty much all of these, hopefully someone else has encountered this random issue.
  • Like 1
Oi man had identical problem with my 32 and i mean IDENTICAL. Ur windows probably don't work either ?i also kept blowing the accessories fuse. In my case i slammed it in reverse too had and the speed sensor plug fell out of the gear box. All that had to be done was plug it back in. Just look on the drivers side of the gear box and see if there's a loose plug or something like that.
040122, Crawled around the gearbox for awhile, but no joy on anything unplugged or loose. Since I was using the cruddy screw-jack from a friends car, I couldn't get very far under it to look up higher. It's sad I have to ask, but I want to eliminate every possibility, where exactly on the gearbox is the plug located, just so I can be doubly certain?
Also, thanks a million for the input!
Well if its an rb20 gearbox then it should be on the drivers side of the box, bout half way between the top and bottom.....i think, it was easier for me as i have a pit, just got in there with a torch. Are u blowing the accessories fuse? Check that n maybe Google speed sensor for rb. My power steering also screwed up with all those other symtons . Ps replacing the blown fuse won't fix it until after the sensor is fixed.
Alright, I lifted her up and poked around the gearbox, no plugs hanging, all accounted for. So, I started checking everything for continuity back with a Multimeter, and I found my problem. I'm sort of embarrassed to admit this, really, but it was a very stupid oversight. I had compared my bay fusebox with every other R32 on base here, GTS-t, GTS-4, GTRs, all of them run with no 75A Main Fuse. Apparently, for reasons I don't want to look into, I do need that 75A Main, because I bridged it with a bit of speaker wire and, lo and behold, all my accessories work fine. Thanks for all the input, though, I really appreciate the friendly help!
  • 6 years later...
    • Knowing how slow their other compressors are that connect to the cars battery, you'd want to hope it's one hell of a slow leak!
    • So why can’t the front pipe just be listed as custom make? why does everything have to have a brand name to it? or if you have bought the car like this and have no idea about anything at all or no knowledge what so ever of parts how are you supposed to inform them of what it is you have exactly?
    • Yep, I'd be interested to hear how it works out in the end.
    • Because all parts that are put into your papers usually are assigned a badging if they did not come with one. So other people can just check that badging to tell if it is the parts your papes outline. But my pipe has NOTHING on it whatsoever. No idea why this even passed as a Mines pipe to begin with. I see this going two ways: -nobody cares and it's a non-issue, but that is unlikely -the pipe will just have to be assigned a bagding, for sake of argument, a Mines logo, and the papers corrected accordingly If it interests you I will post what the actual solution ended up being. All I care about is that it has to sound equal length and nobody can screw me later on because of a pipe being illegal.
    • The fasteners to the pipe are not subject to TÜV I guess, if we really start putting nuts and bolts through technical tests I'm going to hang the people responsible and then myself. Usually on a modern-ish EU normed car, you would just replace the pipe. Because if you start hacking away at it and welding new pieces on the cops will definitely find a reason to tow your car. That is just how it is sadly. On old cars and imports with no clear "standard" stuff like that won't matter too much. Most cops or inspectors probably won't even really know what they are looking at. But there is experts for this stuff even among cops, and some of them know the rules to a T and even have extensive knowledge about many vehicles. For "just a pipe" to be legal it usually is included in a set of parts, like a complete intake kit or a full exhaust. For example my exhaust needs to pass a noise test, meaning they have a standardized test track with a set of instructions and they run the car through there 3x for an average noise value that is 75dB(a) at point x of the test track. If it's above that, fail. For a turbo setup to be put in your papers you have to do dyno runs, emissions testing etc. So quite costly
