Thought it was about time I gave a bit of details about my motor since I've been using this forum a fair amount. I'd been saving for an Imprezza when a friend pointed this out to me and for £1100 at new year I ended up with a RS4 Stagea:
First job was to get rid of the "jdm" stickers on the back, and got rid of the rs4 and nismo badges on the back too. Stageas are very rare over here so wanted these off to it doesn't look too special, going for a sleeper effect:
After:
Didn't have any mats so managed to get a set of r34 gtt ones off a friend, and fitted an alpine headunit:
Took the door cars out to look at the speakers and found they'd already been replaced with Sony ones, winner!
Ordered and fitted some BC coilovers in some fine British weather which improved the handling a hell of a lot:
Not sure if the laws the same in Oz, but over here you need to have a rear fog light, so all imports have to have a hanging one fitted which doesn't look great. As the Stag has two reversing light and you only need one I simply cut the feed to one, put a red bulb in and wired the fog light up to it, making the back end look tidier:
Next the car went into a bodyshop for a week to have the rust below the wing mirrors sorted, along with under the bonnet at the top of the suspension. This eliminated all of the rust on it.
Had a very busy weekend following that where I removed the airbox and put a HKS mushroom filter in, adjusted the coilovers, fitted 350Z wheels and replaced the exhaust with a Blitz Nur Spec R system, decat, and 3 inch downpipe. A subtle but deep tone from the exhaust now.
Brought a set of R32 Gtr front seats and some sabelt double release 4 point harnesses to help keep my ass in place while driving:
Then a HKS EVC4 for boost control and also acts as a boost gauge:
Then got a set of R33 GTS-T brake calipers were then bought, I painted them and fitted them with red stuff pads and dimpled and slotted pads:
This is now where the car currently stands after I've owned her for almost 3 months. All the work has been done by myself (apart from the rust repair) with the help of friends.
https://www.sau.com.au/forums/topic/421850-liammph-uks-rs4/
well done liam ,it's proggressing nicely, some cosmetics( body kit) and engine management(safc etc) and your nearly there......and then when you get bored with that stick in a rb26 and manual box :rolleyes:
https://www.sau.com.au/forums/topic/421850-liammph-uks-rs4/#findComment-6786993
Not really going to do anything else with the body, don't want it looking fast, love the look on people's faces when it flies past. Manual box and hybrid turbo is the next job, then fmic, remap and a few other bits and pieces and should be running around 400bhp
https://www.sau.com.au/forums/topic/421850-liammph-uks-rs4/#findComment-6786997
The new wheels and coilovers make a huge improvement on the appearance. Nice one.
I always think that they look slightly naked without a rear wing, but that's probably because mine is... well, large.
Photo credit: Previous owner (SmokeyV35)
https://www.sau.com.au/forums/topic/421850-liammph-uks-rs4/#findComment-6787610
I reckon chuck some s2 tail lights in as well always look cleaner, I agree with marshstag big rear wing finishes stag lines off perfectly I like them so much I got two rear wings , good job
https://www.sau.com.au/forums/topic/421850-liammph-uks-rs4/#findComment-6787934
  • 3 weeks later...
s2 tail lights are just the clear looking ones, just makes it look a lot more modern
have a look on ebay for an autech rear spoiler too, i reckon they look the best!
You must be doing pretty well over there with the snow at the moment, the manual box will make it a lot more fun :P
https://www.sau.com.au/forums/topic/421850-liammph-uks-rs4/#findComment-6803319
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Gotta admit, I love the 20b Cosmo.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
