i have noticed a few cars on here and in other forums running stock motors (internals) but have bolt on mods - and ppl are running NOS -
for example if your running 300kw rb25det plus a shot of NOS how much more damage/ AND RISK IS THIS?
i see these guys are consistantly running drags, with simlar set ups.
is this worth the money / risk.
my car will see a drag stripp once or twice a year - and hopefully powercruise so it will not be getting thumpped that often-
just after opinions and experience
https://www.sau.com.au/forums/topic/421852-nos-on-stock-motor/
  • 1 month later...
Nitrous is a way of boosting horsepower and torque.
No inherant 'risk' that is different to other forms of tuning . The fnf franchise is not an education on this topic.
Things to consider;
The horsepower and Torque limits of the engine and drivetrain. A simplistic way to understand this. If you have 200kw and the internals limit somwhere is 300kw thenyou have 100kw to play with. Nitrous and or turbo bolt ons etc. leave you 100kw to play with.
The fuel system needs to be able to deliver the fuel.
The engine timing needs to be adjusted / mapped with a reduction in advance.
Copper plugs with appropriate gaps and heat range.
It's the cheapest way to add significant horsepower to a stocker for 1/4mile use. I would suggest that 10 seconds isn't out of the question with the car setup and motor and turbo stock.
The risk is the same for breakage for a similar powered turbo upgrade, however in a basic control (no two stage) big shot there is going to be bulk torque over a turbo size for the same power and that torque will put more hurt on the drive train and the rods in the motor.
It's cheap to do and you get good value for events like that. I'd reccomend it for sure.
Appart from using some bigger single kits on V8's. I have experience putting a kit on a standard turbo and motor R33 gtst. 2rismo bought the bits off me then upgraded it further (he ran 11's on a stock turbo'd motor with a small shot).
My view is that you could setup a bigger hit and get a stock motor & turbo gtst into 10's with the right strategy. No special fuel.
It's pretty easy and you won't regret it. Just ensure you do it in a way that is legal (have the kit easy to remove and install) and do it properly with a plan in mind , considering the limits and supporting modifications you would do for any power upgrade.
  • 1 month later...
  • 1 year later...
  • 4 months later...
  • 3 weeks later...
    • Big single, and seqy. #sorted
    • The R32 suffers from an instrument binnacle that is uncomfortably close to the design of a VN Commodore's. But beyond that, the layout of the rest of everything, and the materials (ie the vinyl coverings on dash, armrest, etc) are acceptable, and the patterns on the fabrics are not as blergh as those in the R33. And R33 seats are....quite unattractive. I know it's only small details there, but I reckon the R33 got worse than the 32. But the big blergh is the overall shape of the dash on the R33. It's just has that whole Maxima/Pulsar sort of look to it. Nothing special at all. Generic Nissan sedan. Whereas, at least the R32 dash/binnacle was different. Less a wide expanse of boringly curved plastic. More a "cockpit" sort of look, even if nowhere near to the degree that the A90 Supras got. R34 seats look good on their own, until you realise that they are indistinguishable from the shape and fabric on 70 other Japanese cars. And the foam bolsters on them suffer even worse than the earlier cars. Other than that I don't really have an opinion the rest of the R34 interior. I took the bits of the R34 I wanted (brakes and engine) and added them to the best external appearance Skyline in the modern era (the 32). So nyerr!
    • Can I be your first customer? I would like hard lines done for the fuel system, 8AN up and 8AN back and the underside wire wheeled and coated (brush or sprayed) with that black tar shit.
    • Speak for yourself, I love the R33 interior. 32 is blergh. I like the 34 interior too. Then you start getting much newer in most cars and they all turn back to blergh. 馃槢
    • 500-600hp into a RB is already 'sinking endless amounts of money' into an engine. Especially a 30 year old engine. Unfortunately this is the RB Game. Considering stock power (or at least stock components) will do ~360whp on 98 by simply turning up the boost on the stock gear on a RB26, that would be where I'd say the cutoff point for "sinking endless amounts of money into the engine" Cause to even do this reliably you'd probably need to replace all the bits anyway cause they're old, starting your sinking journey anyway. I reckon the least painful way is rebuilding the engine to make 50hp over stock lol. The 'plan your ownership around a rebuild' was a common saying 15 years ago.
