I just made mine, my little plasma cutter wouldn't work on such thick material so I just drilled lots of holes, punched the centre out and filed it. 10mm would be a lot easier than 20mm though. :P
Disco, make sure you delete your BOV and install a nice intake pipe with a pod filter.
I want to hear it go ssuuuuuu tuuutuutu hahaha.. (as if you would do it)
On the other hand, can't wait till you do it. Will be following this thread
  • 3 months later...
Can anyone using GCGs split GT30 IW Skyline dump tell me if they work properly or not . If it's a lemon I'll get one made but if its alright I'll get one to speed up the fitting process . So close I can smell that 76 52T and I want to see it working .
Mick O your front dump used a divorced WG pipe , was the gate side of the dump flange matched to the turbine housing port or just hole sawed like GCGs ?
Thanks all cheers Adrian .
PS Ch cha cha cha - nah . Hopefully won't do that so much through the std airbox . Actuator is 1 bar big can if it makes any difference .
Im reasonably sure I have one. (bought second hand) no worries with it. I know the concern of sticking flap etc with splitdumps on stock housings, but its not a prob with the gt30 housing.
Pretty sure mine matched disco but not 100% sure either to be honest.. All I know is it did work as I made great power and never had any boost control issues at all :)
Yes the plate could be ground but the reason it was done with a hole saw is to weld a round tube to it rather than form it to suit the profile of the housing . In my mind IWGs need to have everything going for them to work properly though in this case no ones said they don't work .
ATP in the past made a dump for something similar so I'll see if I can find pics of it .
A .
I don't think it was done with a hole saw. The whole thing is a laser or plasma cut flange, there's no way they made the round hole with a hole saw.
So to clarify, mine has a round hole for the wastegate.
There is an old thread here called "Boost Creep Gt3076" and I tried linking with no success .
The second page second post shows a pic of Mr Mafias Front/dump from the turbo end and you can clearly see the round hole for the gates separate pipe .
The GCG one looks very similar to this , quite frankly it doesn't matter if the round gates outlet hole was created by a hole saw or cutter because it's the size and shape of this "orifice" that may not be ideal .
Checkbuzz makes interesting comments about replacing his GTRS with a 0.82 IW 3076R 52T , as in similar response but more of everything everywhere . Have mentioned this at times and most people find it very hard to believe . I'm sceptical but aim to find out myself . I sort of hope I'll get what Mr Mafia got with a larger 0.82 hot side and smaller 52 vs 56T GT37 compressor . Common factor is the GT30 turbine and the realist in me says nah got to be significantly heavier than a GT28 turbine and inertia is inertia .
Does anyone have pics of a bell mouth dump on their std manifold mounted GT30 IW turbo ?
Want this happening next time I get a string of week days off , cheers A .
I'm not going with the GCG dump , I went to Best Mufflers at Carlton this afternoon and they sold me the best GT30IW dump flange I've seen to date . It's designed for an open collector and the feller reckons forming a stainless 3 1/2" bend to it should work .
I was going to stay with a 3" front pipe just to keep it reasonably compact , in stainless so it can be wrapped to keep the heat out of the bay and the interior .
A .
They do but I'm not going that way . The front is a pipe kit Scotty here made to mate the 4 inch inlet to the std/Z32 AFM and the other two pipes .
I found this pic on Google images CO SAu yesterday . I'd like to see the other side of the front flange but it doesn't look too involved .
Still amazed no one makes these for such a common conversion , anyway off to see someone tomorrow who can fit and make a similar kind of thing .
A .
Unfortunately the Fords turbo is on the drivers side of the engine so the rectangular gate outlet section points downwards towards the inside radius of the dumps first bend . An RB with a std manifold on the other side mounts the turbo with the rectangular section pointing up so the tube has to be formed with the matching section for the gates outlet on the outer radius side of the first bend .
An open (bell type) flange for these housings is quite large and that's why I think so many Ford ones are made of 4" tube , so it doesn't "underlap" the perimeter of the shaped hole through the plate .
4" is pretty big for a 2.5L engine so it probably needs to neck down somehow to maybe 3- 3 1/4" back to the cat . Stainless so it can be heat wrapped .
Going to see someone about it this morning so more later .
A .
The mob I wanted to do the conversion doesn't want to do the dump but they put me on to Peter at Kirrawee Mufflers and he has a few ideas . He showed me a sawn off XR6T first dump section in 4" stainless and his tig welds look pretty good to me .
Another suggestion he has is to use a 3 1/2" stainless bend which is about right for the main outlet and make a curved channel to house the gates outlet section , with a matching section cut out of the main tube .
I'm curious to hear about dump pipe tube diameter as it seems anything from 3-4" could be used though 3 1/2 or less is probably easier to package underneath to the cat .
I'm expecting the exhaust note/volume to change going from the GT28 to the GT30 hot side and dump section .
A .
It will be louder...
I would go 3.5 inch on the dump, and taper it back to 3 inch at the cat usually for that sized turbo. (unless you want to run 3.5 the whole way.)
3.5" the whole way :D
DO IT..
I'm going to do that when I decide to plumb my external back.
    • We are literally just kids stuck in an adult's body with bills and mortgages to pay 🥲
    • Behrman is great quality stuff. My 34 has some serious clouding as well but I’m too nervous to try and replace the glass myself so I haven’t bought them yet.
    • This might be true if you live in NZ but I can't see how this could be true for us locals here.  I've found the customer support for Haltech to be absolutely amazing. I've turned up to Haltech and spent entire days with their tech support guys, they've even helped me with wiring dramas that had nothing to do with their products.  They have the best customer support of any company I've dealt with, I can't imagine how my experiences with them could possibly be any better.
    • If you want to do a single throttle body conversion easily, you won't need to pull anything apart. Take the linkage from your throttle off the linkage controlling the ITBs. Now open the ITBs wide open, and lock the linkages in said position. Now add a single throttle body onto the front of your inlet plenum. No it's not ideal for the last nth of a kw, but it'll be a lot better than what you're already trying to do...   PS, ITBs can be so damn hard to tune from, because roughly 20% movement in a throttle body equates to a change in roughly 80% of its flow (Hence power). When you add up the flow limitations of those small throttle bodys, it is a LOT higher than that of a single large throttle. Hence, TPS is very very sensitive with them, and you do a LOT of work with sensor fusion, and some Maths behind the scenes to make those blends nice, and be smooth.
    • Yep, when Haltech purchased Adaptronic, and all of the Adaptronic staff, including Andy went with it, it took Haltech to the next level. Haltech wanted Adaptronic as they wanted things like Andy's fuel models, and some other IP, AND they wanted Andy too as he is brilliant! Andy has spoken about the incompatibilities between the old 1500 stuff vs Nexxus, and it totally makes sense. It's not JUST software that is different, there is huge changes in the underlying hardware too. It's why Haltech has had soooo many changes in the last couple of years, in terms of Hardware, and Software, and why it has become so damn Amazing. Why do you think guys like Rob Dahm with his quad rotor, went from running Adaptronic's to running Haltechs? Andy. Pretty much, Haltech these days, is Adaptronic, but with more funds behind it, and more staff, and hence Andy's visions, and visions of other people that he helps shape their great visions, into amazing new products. All the new Nexxus gear, whole new software for it, new and better dashboards, the apps that will run on headunits and NOT be slow to respond! I understand people being burnt in the past, but if you're ragging on a company, about products and issues from many years ago, it's more a reflection on yourself, not looking or keeping up with new stuff. In which case, those people should be going back to PowerFC and Nistunes as the ECU's to rave on about...
