Hey Crew.
Im currently modifing an RB25 Intake Manifold.
The issue ive discovered is that the metal push in radiator fitting has started to rust inside the manifold and will start leaking.
The manifold is off now and we have modified it substantially to accept RB26 ITB's so we dont really want to have to start with another manifold.
What are my options in replacing the Metal insert?
Are they eay to remove? if anyone has done it before id appreciate some tips.
Im looking at replacing it with a peice of Billet alluminium that has a push on fitting as per the standard item.
Does anyone out there know of an alternative 35mm OD Billet water push on stlye peice thats available off the shelf?
If found this from datsport in SA id have to machine of the 3 bolt mounting plate but it should push in to the RB manifold with a bit of work.
Id prefer not to Weld if can avoid it rather stay with the OEM method of Glue and press fit a new peice.
http://datsport.com/products/images/cooling-outlet-SR20.gif
If anyone has done this before or has some options id appreciate them.
Regards
https://www.sau.com.au/forums/topic/421876-35mm-rb-skyline-water-outlet/
I had this happen whilst the engine was in the car. I picked up another inlet manifold with a good condition insert for $10 from a wrecker.. Heated the alloy and removed the insert with a pair of multigrips. Then I applied some sealant around it and carefully knocked it into the original manifold with a rubber mallet. Worked fine and has held up for years with no leaks.
This is a common Skyline problem for cars that have been in hard water areas.
Unique Autosports in Sydney make a "Chrome Molly Upper Radiator Outlet for the Intake Manifold" for $65. They had so many cars present for service work with this problem that they designed a replacement part (it is on their website). You simple remove the existing unit and replace it with this one.
Usually coolant systems on cars have a "sacrificial anode" part that is designed to corrode. I suspect the insert is the sacrificial bit, and if that's the case you should be able to buy the insert separately from Nissan. Chrome moly seems like a bad choice as im pretty sure its less reactive than cast iron, so it cant perform the sacrificial anode function.
On older cars i've had the sacrificial anode is the thermostat housing.
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
