Infiniti G35 with excessive oil consumption ... in 1,000 miles or less indicates internal engine issues
In American the 2005 G35 had to offer engine repacement because the oil issues.
Review the dfferent sites to get a handle of the info.
Good luck with your G35......
http://www.6mt.net/forum/g35-sedan-2003-06/26969-g35-purchasing-oil-consumption-issue.html
http://nissan350z-infinitig35oilconsumption.com/
http://g35driver.com/forums/v36-general-tech-questions/181131-oil-burning-issue.html
http://forums.nicoclub.com/g37-owners-must-read-t369083.html
Hey Guys...
I have a non rev engine and I am replacing oil so fast, I would say about every 2K.
This is FYI and if you don't have this problem, cool.
I can care less where the engine was made..
When it's an import there is no company warranty, so replacing the engine like in American is not an option.
I hope it's just me with this problem!!!
Brian
Warranty Company like National Warranty Company are scams anyway, Nagoya scammed me $2000 for a warranty that was 100% supposed to give me $5000 engine cover for this sort of thing. I cant use it one bit, its completely useless, NWC.com.au pull the "normal wear and tear" and consequential BS card and pay nothing.. I would try replacing the PCV valve, get quality oil catch can inbetween the PCV and plenum, get new valve cover gaskets, replace spark plugs and start using 5W 40 Shell-Rotella-T6 Oil and you will have alot less usage. If still an issue then worn rings.
Lol. Its not a Kingswood!
Its pretty easy to find where your losing the oil. Your either leaking it or burning it. Make sure your oil measurements are "scientific" (ie repeatable). That means, car dead cold on a flat surface.
VQs do have a bit of blow by, and this can lead to oil getting pushed through the PCV and burned. An inspection of the internal of the plenum will tell you how bad it has been. I have seen bad, and have seen almost brand new as well. Other typical VQ traits are the spark plug tube seals leaking, rocker cover gaskets leaking oil, and a weap out the sump plug if the washer isn't fresh.
check your exhaust in the morning/ cold start! give it slight rev and get someone to look at the exhaust, a blue tinge smoke usually means you're burning oil so the issue may be that the rings are just worn and you end up burning most of your oil. this is very common for engines that had either a factory fault minor manufacturing defects or engines that have been revved and abused like crazy.
Try a thicker oil and see how you go. also check under the car for oil spots that may be a clear indicator of a leak.
as for warranty for engines. you have to prove to them the leak is a faulty component and not a wear and tear as normal wear and tear is a minor amount of oil being burnt or lost thru normal day to day driving but if u run out of oil after 2000k that is not normal for an engine.
something like this sounds like an engine rebuild / recondition. like changing seals and piston rings and the likes. witch is time consuming.
I am not leaking any oil...I have check this often....
I will double check my exhaust in the morning...
From what I have read in America..this is common but the car, engine run fully fine....and fast....well for a G35..LOL
THANKS EVERYONE!!
Like I said before....I wanted to see if anyone else had this small issue...
I use Mobil 5-30 and my car has 150,000Km on ODO. change the oil every 5000 to 10 000 Km and every time i lose close to 0.5L so to me it sounds like your car burns oil or its losing it somewhere else. i recommend getting a qualified mechanic or someone that knows what they are doing and do a major service and have them change all fluids and keep an eye out for extra oil or oil in that fluid. like oil in the coolant ( bad sign ) then make sure you do a full flush of the oil and put in a thicker oil. 10w40 sounds a bit to thick but i know people that run it on newer models that are are above 100 000 km and have no dramas in fact recommend it
