So I’ve got a new turbo on the way from Hypergear and wanted check whether I’ve got my supporting mods covered. The handling and brake upgrades etc have been done.
The car: '99 C34s2 RS4-S Stagea
Current Mods:
  • Greddy Front Mount Intercooler
  • 3" Full stainless steel Fujitsubo exhaust and stainless steel front pipe with 3" Venom 200cpi hi-flow cat
  • Nistune ECU
  • Turbosmart Boost Tee
  • Nismo High-Flow Volume Fuel Pump
  • HKS Panel Filter
The turbo: Hypergear ATR43SS2 inc billet comp wheel, oil line and 14psi actuator with Nissan 6bolt OEM assembly.
Mods to be installed with turbo:
  • Nismo 480cc Injectors
  • Z32 AFM
  • Scotty metal intake pipe
Is there anything else I should be considering? Subscribing to the “do it once, do it right” philosophy here, so would much rather spend a bit more on quality parts now rather than have troubles and/or dissatisfaction down the track.
Would it be worth ditching the Turbosmart Boost Tee in favour of a Greddy Profec B Spec II? Is upgrading to a Splitfire coilpack going to make a difference?
Cheers guys.
https://www.sau.com.au/forums/topic/421928-pre-turbo-upgrade-mod-checklist/
The t will be fine my greedy boost controller sits in the car not hooked up just ended up using a t much easier to tune with and if your stock coil packs are holding up they will be fine too but some time down the track they will need replacing , have you got the plug with afm
Cool. Yep the one I bought comes with a Tomei plug.
i basically done everything u done above with same turbo except for the injectors and only have cat back zaust.
Main mods i would have liked to have completed if funds permitted would have been injectors, dump pipe, ebc, shift kit, cams & greddy plenum. Its a good turbo by the way excellent midrange
Internal gate, so a EBC might be worth it... depending how hard you want to lean on it .External gates are a different story.
Ill be interested to see how it goes, was so close to getting the ss2
cheers
darren
Yeah I'm worried about it being too laggy... my understanding is that an EBC can help bring boost on sooner?
R34 GTT Brake conversion...
You might as well do oil and plugs while your at it... especially plugs before a tune.
Gaskets (as above) and vac line.
I'm interested to see how you go with the ss2 on a heavy stag.
Cheers
Justin
PS... an ebc will only bring the boost on sooner if the actuator is 'blowing' open prematurely. it can't make the turbo spool any faster.
It has R33 gts-t brakes with slotted rotors atm.
I should probably mention that I'll be getting this all done at a workshop... I'm not game to tackle something this big!
Edited by Marshstag
Fuel pump?
See first post - it has a Nismo fuel pump ;)
Ouch work shop sounds expensive
Yeah it won't be cheap, but at least it will all be installed at once and then tuned. Thus my reason for wanting to make sure I haven't overlooked anything!
Just out of curiosity Andrew, what kind of costs have you been quoted for the new Turbo and Injectors, etc? Interested in doing those upgrades as well, I've got the same (almost identical) Mods to you at the moment, so I'm pretty keen to know what I'd be up for.
In relation to the SplitFire coil packs, I'd highly recommend the upgrade, whether your existing packs are good or not, if you've got the cash to spare, get the new packs, you won't regret it. The existing stock coilpacks will most definitely shit themselves at some stage.
The total for the turbo as described above was $1500 delivered. PM Stao from Hypergear for a quote.
The injectors, I'm getting through forum member 'elrodeo666'. Marcus is able to order directly from Nismo in Japan. The total was $725 delivered.
Who's tuning/fitting it all ?, i got the G3 type A, be interesting to see the difference when finished, mines auto though
Your car will be a allrounder after turbo fitment, looks so bloody good , will have the speed to go with it to !
cheers
darren
Edited by jet_r31
    • My extinguisher mounted like this unscrewed a little (Maybe from the chair sliding forward) and dumped a bit of white on my mats. I'll need to get a more narrow one for future.
    • I totally couldn't do the whole kids taking up my life thing! 😮 I find it bad enough doing 45 hours in 4 days, and then fitting normal adulting life into the other 3 with no kids! As for my mates race cars, they're AMG C63 setup for production racing. The original is what has just been stripped and a brand new shell built. The original is then going away to have some panels straightened, then it will be put back together again. Then there's a third that will shortly head off to have a roll cage put in, then build it up too. And potentially a fourth to be built too... Oh, and he has two Renault Clio D class production cars, ha ha. And when he's not racing them in the Australians and QLD production championships, he's been racing one of Chaz Mostert's Lamborghini's in GT4. They just won GT4 at the 12 hour in the Lambo. We're pushing to finish the new AMG as it has its first round (and potentially its first shakedown/outing) in under w weeks for Round one of QPC, and that round is really the shakedown to make sure it's all good for the Bathurst 6 hour, which I'll be at too. Ha ha ha Working on my project is different to his, I slowly tinker and work ways to make things happen on a shoe string budget. Hes in a good position that he has a massive workshop full of parts and tools, ha ha. He also looks after me. When his air compressor died, he just needed it working, so bought himself a new one and gave the old to me. Sand blaster unit too, and a 20t pressing. And pretty much all the shelving in my shed too as he upgraded all of his (the stuff he gave me is the expensive black Bunnings heavy duty stuff)!   I enjoy working on his stuff. No decision paralysis, and anything that's needed parts wise is just there. Plus, then I get to be hands on at the track in real racing, not just club day stuff.
    • I know which one I'd prefer to have in my garage, and which one I'd actually drive as intended
    • Yeah mate, no probs. Just swap the email addresses?
    • I definitely agree with you there - I never click on content for cars I would never ever be able to get or compete with/against/be seen next to. Seeing a MX5 compete with a FD RX7 will make people upset though, for sure. Even in 2.5L Turbo form which is pretty grass roots. (or at least as grass roots as classic cars can be) Yes we're all classic car owners now.
