Purchased at the end of 2011 for $1200 (will include original invoice). Selling for $800,includes original charger and a sony soft case to suit.
Hardly used, literally used a handful of times. This was an impulse buy that i do not need.
Features as per the description is listed. Please message me for any more questions
Key Features
788b_10.JPG2nd Gen Intel Core i7 -2630QM - 2.90Ghz
788b_10.JPG17.3" LED High Definition (1600x900) 788b_10.JPGHUGE 640GB(HDD) ULTRA SATA DUAL Hard Drive 788b_10.JPG8GB Memory ( DDR3 RAM) 8GB MAX 788b_10.JPG Build in Web Camera + Fingerscanner 788b_10.JPG1GB ATI Mobility Radeon HD 6 Series Graphics 788b_10.JPGBLU-RAY Multi 8x DVD+RW -Write DVD and CD 788b_10.JPG 5 in 1 Media Card Reader - Reads most of Memory Cards
788b_10.JPGBluetooth+ Wireless Internet with WIFI A/B/G/N Wireless Card
788b_10.JPG Microsoft® Windows® 7 Premium 64bit !
Located in Cleveland, QLD. Welcome to come inspect or can arranged insured postage australia wide.
hey mate just saw an add for a very similar specd hp at harvey norman.
newer/faster i7, 750gb hd, 8gb ram, windows 8, just doesnt have blu ray, for $792.
just a heads up.
glws.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
    • Right, but if you replace the pump gears + put a spline or sine drive gear on the crank on a Nismo/OEM/N1/etc pump at that point do you really still want more flow/oil pressure? Let's say this is a the aforementioned "keep it simple" build, no more than ~400 kW at the crank.
    • Strength. And on the early RB26, full engagement of the pump drive.
    • I really don't understand the point of aftermarket oil pumps if your particular engine doesn't need more oil pressure. As far as I can make sense of it the problem seems to be cavitation from sucking air, maybe the pump gear design with how it interfaces with the OEM crank, and maybe the backing plate screws wanting to loosen themselves. How does flowing more oil fix these issues?
