1992 Black R32 gts-t.
DRIVELINE:
-Series 2 RB25DET motor and gearbox
-Rebalanced KKR430 turbo
-3" Turbo back exhaust (from cat back is Bee Racing(Bee*R) from Japan)
-Microtech LT-16S ECU w/ MAP sensor
-Splitfire coils
-OSGiken Camgear
-Gates Racing timing belt/tensioners/idler pulley
-Sard fpr
- Walbro 255l/hr fuel pump
-Blitz pod filter
-JustJap 600x300 FMIC
-Exedy Sport tuff clutch (the pink pressure plate ones)
-Gibson motorsport custom 3" single piece tailshaft.
-Tuned by DAT performace (the guy who does the dyno at Powercruise)
-Makes 239kW at only 12psi NO LAG! Have dyno sheets.
SUSPENSION/BRAKES:
-HSD coilovers
-Bee*R pineapple bushes (subframe collars)
-KKR Castor rods
-HICAS lock-bar
-DBA Slotted rotors
-QFM700 pads all-round (outperform redstuff)
-Can provide front strut brace
WHEELS AND TYRES:
-18x10 +18 Work Emotion XD9s
-235/40R18 Federal 595s all round with 90% tread
-Guards rolled and pumped to fit the rims
INTERIOR:
-Red BRIDE Cuga Carbon-fibre Drivers seat
-R33 GT-R Passenger seat
-Deep dish suede wheel with yellow centre marker
-Microtech control unit
-Pioneer head unit with bluetooth handsfree
-Pioneer speakers all round
$9500
Car will be sold with RWC, can register at buyers cost after deposit put down if convenient for buyer.
Contact Jono: 0421 308 872
post-46140-0-64362100-1363682653_thumb.jpgpost-46140-0-61819200-1363682666_thumb.jpgpost-46140-0-72524300-1363682788_thumb.jpgpost-46140-0-44757900-1363682804_thumb.jpg
https://www.sau.com.au/forums/topic/421954-qld-1992-r32-gtst-with-rb25det/
I bought the car near stock in 2007 from its first aussie owner 21000km ago, engine and gearbox came from a front cut series 2 R33 with 80000km on the clock and was put in the car just under 5000km ago
I built this car to have real world performance and be drivable and well mannered on the street, things look very stealth under the bonnet and in almost 6 years of ownership the car has never been defected. with some injectors 18-20psi and a small edit to the tune, this car would see 270rwkw+ with no issues.
car will be sold with RWC, can register once deposit taken if preferred (at buyers cost).
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
