Hey,
I bought a 98 r32gtst a month ago as it drives like a new car beautiful tight shifting no dents at all perfect original interior everything is still rigid good smooth motor.
It has a front mount, podfilter, 3.5inch catback, per4manz highflow turbo from perth a while ago with garret guts and bush bearings, it reads 15 psi full boost. The only thing im a bit worried about is that it isnt tuned at all!!!!! it runs smooth and everything but exhausts some black smoke when i spool it so i guess its rich, but its not tuned??? i thougt it would run lean with a turbo upgrade.. plus its real laggy do you think thats because of the stock down pipe + non ball bearing turb + plus big intercooler + rb20 ?
the other question would a tune make it spool earlier? it pulls at 4.5k i raced a standard r33 the other day and it only just beat me would a tune make it less laggy and alot faster? coz it still lost to a standard 33 with all my upgardes...? cheers
https://www.sau.com.au/forums/topic/421961-rb20-isnt-tuned/
it wasnt advertised as being tuned, i just think its good because its smooth and still new inside out, is a rb25 highflow considered big? do you think im okay to keep running 15psi with this non tuned set up doesnt overheat or sttutter or anything.
Why would you expect it to "stutter" anyway. There are three things that can be wrong with the tune on a stock motor that is boosted up;
1) Stock maps too rich = less power than ideal, black smoke and fast dropping fuel gauge.
2) Run out of injector = possibly goes lean at peak torque rpm and above. Car will feel fast, no black smoke but may start pinging. Pinging may be inaudible but still cause damage.
3) Timing maps not optimised. If stock, they're probably too soft anyway, unless perchance it's running lean enough to cause you trouble, see 2) above.
So, in all of that, there's no "stutter". There's either runs real nice, runs real nice with smoke, or runs real nice with possible invisible engine damage occurring.
It would be smart to put it on a dyno with a wideband and knock ears connected and see which of those above are the actual case, no?
https://www.sau.com.au/forums/topic/421961-rb20-isnt-tuned/#findComment-6789087
okay cheers, a mate was driving behind me and said it pisses black smoke when it hits full boost at 4.5k so it must be rich would a tune make it much quicker? its just a tad slower than a stock r33 so im guessing with weight factored in it would be like 160kw?? what could i maybe get with a decent tune at allstar garage in perth or something like that... i know nothing about tuning.
https://www.sau.com.au/forums/topic/421961-rb20-isnt-tuned/#findComment-6789100
It's slow because it's taking forever to come on boost and running too rich. An R33 highflow on RB20 should be up above 180rwkW, probably pushingover 200 depending on the exact nature of the turbo (and assuming that there is sufficient injector).
I made 170rwkW (or thereabouts) on a stock RB20 turbo just with the usual minimal mods.....big exhaust, FMIC, decent intake to and from stock airbox and Nistuned ECU. The only thing holding me back from making more was that injectors were at 100%, AFM was pretty well on 100%, turbo was at 14 psi, so nothing really left in that either. Needed upgrades to all these before being able to get any more power.
https://www.sau.com.au/forums/topic/421961-rb20-isnt-tuned/#findComment-6789112
    • Good tips, will get on those tomorrow. When doing the maintenance I did move a few of those connectors around, and things that are old tend to not like moving around. (Like me).
    • Don't try it. It will be shit. Better chance of damaging the engine than gaining any knowledge about the old one. Maybe, but unlikely, especially if the O2 sensor is working. You can use NissDataScan to look at the stock ECU.   Cleaning the AFM is seldom necessary and seldom helps. The R35 coil & loom conversion should eliminate dud coils or plugs. But as you still have misses - look to the plug where the coil loom connects to the engine loom, and the CAS plug. Need quality connections there. Also look to injector plugs. And the AFM plug while you're at it. Also look to whether your injectors are clean and flowing evenly. Get them out and onto a testbench.
    • Good to know, I feel like I am in for a rollercoaster ride that looks like a sine wave.
    • You'll fit right in. Acceptance is the first step.
    • Hey folks. I've been lurking and browsing the forum for a while, since I got into my head that I wanted a skyline. Having purchased an overpriced completely stock GTT, (only "mods" it has is HKS pod filter and catback) now that it became legal in the US, it was all glorious and sututu noises here and there. But then I wanted to do things right and went to do basic maintenance. After all the fluids, filters done, I did the spark plugs, that's when the problems started.. First the car started spluttering at around 4.5k RPM. Which I gapped down the new plugs and that solved the sputter there, but the car now always misfires at idle with pops when lifting off and shifting 2nd to 3rd. Similar to the issues in this recent thread. I've been banging my head against the wall, reading the threads here and trying suggestions for a couple months now, so decided to start this one to explain exactly what I tried and what is going on. The symptoms of the issue: Idle and low revs misfiring intermittently. You can hear the exhaust tone change and the shakes on the shifter knob. It happens frequently, but doesn't seem to have a rhythm to it. Pops when backing off throttle. It pops and or burbles almost feels like it spits fire when it pops. (Happens mostly in 3rd gear at around 2k RPM). When under load and after 6k RPM, it also pops when shifting from 2nd to 3rd. There's a ticking noise at around 2k RPM in 2nd gear going downhill, seems unrelated though but I am out of educated and downright dumb guesses. Not noticeable lack of power when putting the car into load. The attempted diagnosis and solutions: Unplugging coils when the car is running This did nothing to change the idling and tone shift for every cylinder. Checking the exhaust headers with thermometer They all are within what I'd say it is margin of error of the laser thermometer New spark plugs Tossed two new sets, copper, iridium and using the old ones, still misfiring, even re gapped to 0.8mm, still same thing. MAF cleaned with the "specific" spray cleaner No changes in the issues what so ever. Brand new loom and r35 coil conversion (was going to add the r35 coils anyway) car runs arguably better, still misfires, but seems like does less frequently. Placebo? Code 21 now being thrown, thanks nissan gods. Removed the CAS to check the shaft for play or anything. CAS seems all fine, nothing that indicates any issue, visually speaking. Things to attempted next: Ordered a new MAF (chinesium from Amazon, to be able to return regardless of result). Fuel with proper gas, maybe it is this California water that they sell as gas that is to blame? Plugin the link ECU and check the info using the built in base map. Go back to BMW and eat my rob bearing breakfast without milky oil mixture.   Do any of you have experienced anything like this or have any suggestion?
