  • Replies 53
Thanks DaiOni.Good post.Do you have any japanese links?
Evo_lee,SKY031 I know it is not any problems finding forums and sites from the net,but I am after information from Japan about tuning and styling.About any support for these kind of cars like with the ae86 and S13 which still is supported in Japan.
Thanks
Paal
CM...
Tuning support and parts for:
Toyota: Mr2, Celica, Supra - vastly available, though the Celica isn't very popular.
Nissan: Bluebird Sr turbo, Silvia, 300zx - vastly available.
Mazda: Cosmo, 323 gti - speciality shops...still OK.
Honda: Prelude, Civic 1.6 Vtec (Sir) - vastly available, but the prelude isn't very popular.
links for?  exactly what kind of info do you need?
try the japan links sticky on the japan forum page
Japanese forums or any clubs in Japan with pictures if there are any?
Thanks
Paal
theres the Jenesis Dr30 site, along with a few local dr30. Searching on google is'nt the best way. I can rarely find any info about whatever i am searching for. For example, if any companies make a front kit for the mz20 soarer, or info about the soarer alone. So i ve taken to using altavista, and with better results. By the way, does anyone know of a mz20 kit?
when u say sr20 bluebird, u mean the japanese one? cause the local 80's one had a L20b.
Don't forget the S12 !
Try here for some info: http://www.club-s12.org/
Without that model, the S13 may have never been born. Overlooked by many these days, and contain many of the features found in later Silvia models. Have seen some cool looking ones around.
I went to buy one locally.. but it was very destroyed when i looked at it. Was hardly worth it - so i bought an aussie R31. Whilst hardly anything special, where else in the world can you find an RB30E skyline? hmm, ok i think South Africa as well.. anyhow :)
hachi is (was) cheap too - that's it's real selling point, that's why people drove them - cheap and they did the job. Then along came a cartoon and suddenly the myth outweighed the reality.
it was takumi (which, incidentally, means 'skillful' in japanese) that made the car - and not the other way around.
there's plenty of examples in motorsport where a top driver changed teams, and, suddenly, and 'unbeatable' car suddenly became part of the traffic.
tsuchiya could drive anything, as could shumacher, mccray, etc etc etc.
Yea I see your point, it wasnt designed as a race machine.
But for Keiichi to buy one and race it, and for it to do well against good drivers in powerfull cars, surely that means something to you?
Ah well, its high in my cool rating, even though its way overpriced at the min.
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
