Check out the exclusive events section, sign up by the end of the week!
http://www.skylinesaustralia.com/forums/topic/421978-certified-100mm/
HERO CAR LINEUP
1. ZOMAYA’S 300KW Lancer Evo
2. VU’S TIME ATTACK Nissan S15
LIVE PERFORMANCES BY
1. Little Jase, BAKESHOP, featuring Karen Esco and BurnCity
FOOD TRUCKS
1. SMOKIN BARRY’S: Slow Cooked Barbeque
2. YOGURDDICTION: Frozen Yogurt Desserts
3. MR BURGER: Burgers and Fries
4. THE PIZZA TRUCK: Pizza
5. WHITE GUY COOKS THAI: Thai
https://www.sau.com.au/forums/topic/421979-certified-100mm/
  • Replies 57
you send in the app form and have to get approved before you can enter
need pics of car and detail of the specs too, they then review and see if your 100mm 'certified'
ROFL!
Where are they measuring the 100mm from?
Sideskirt or exhaust pipe?
https://www.sau.com.au/forums/topic/421979-certified-100mm/#findComment-6789566
It looks promising though, it's pretty much a festival that displays cars
Has live music, food trucks, good location and plenty of cars to check out
Yeah I saw that, was just unsure about the requirements for entering.
I can clearly see they just want quality cars, which is understandable.
https://www.sau.com.au/forums/topic/421979-certified-100mm/#findComment-6789685
The team at 100mm are trying push the evolution of the scene in to the next stage. I see this event as a kind of catalyst to get things moving.
Saying that, there are some impressive cars hanging around SAU VIC and it would be great to see them along at this event.
https://www.sau.com.au/forums/topic/421979-certified-100mm/#findComment-6789690
Yeah, but if you're interested just apply for your car. Won't hurt to see if it makes it or not
Yeah it's a big event, lots of cars coming down from Sydney for this as well
https://www.sau.com.au/forums/topic/421979-certified-100mm/#findComment-6789723
To me it's similar to ESTBLSHD, ran by the same or similar key people in the same group of friends...
Collaborating the Car / Food / Music in Melbourne because these are some of the key features we have here and embrace.
Similar to Hellaflush / Zen Garage / 9K Racing etc... But they all blend the mixture of Cars / Music / Fashion / Models or whatever is "Fresh" at the time.
I do enjoy it all, as it brings coverage / exposure to what we all love.
https://www.sau.com.au/forums/topic/421979-certified-100mm/#findComment-6789733
It is also enhancing the image that general public has of the of the culture. Which is what requires the most work.
https://www.sau.com.au/forums/topic/421979-certified-100mm/#findComment-6789753
    • Nah it factory manual not sure about ratio but it looks like there’s been some work at the rear
    • so I need a new speedo cable
    • Throwing my spoon to the soup here a bit.  When I installed a 044 back in 2012, along with the direct power mod, the car became very difficult to start. To a point I burned one starter motor as I was late for work and tried to get the thing going. With some tuning and careful use of gas pedal when cranking it became bearable. Trying to make this short as possible, but the 044 died after 2-3 years, after which I went with an AEM 320lph pump, which also died after about 4 years to my dismay. After that I went with a Nismo pump, and while trying diagnose an emissions problem, I noticed for the first time that my fuel pressure was 5bar/72psi on idle, and that removing the vacuum line did nothing. After monitoring the situation, and removing the direct power feed and going back to FPCM in attempts to remedy it, I noticed there was fuel in the pressure regulator vac line. Kept the FPCM, installed AEM external regu and the car became sooo much better in every way, including starting. And I had driven it like it was for 11 years.. Anyway, I agree these are likely two different problems, and the FP problem you just haven't noticed before. I do not know much about haltecs, but what first came to mind was the CAS, which probably is not there any more. So how is the wiring from haltec to gauge cluster? How is the battery voltage and alternator?
    • Your car was auto before? You have different diff ratio (auto vs manual i think? or n/a and turbo?)
    • +1 for getting a screen off alibaba, CarPlay/Android Auto is vastly better than whatever navigation cars had 10 years ago. I got an Android screen for my 2015 BMW, huge difference. Fully compatible with factory stuff including iDrive controls.
