R33 gtr inlet manifold $100
R33 gtr ac bracket $25
R33 gtr s1 ecu to engine loom $150
R33 gtr s1 coil pack loom $100
R33 gtr knock sensor/aac valve/ cold start valve loom $100
R33 gtr o2 sensors, look quite newish $50 each or $75 for the pair
Rb25 starter motor $50
Rb25 alternator $50
S15 center console (part with cupholders), inc ashtray $75
S15 coil packs 3, $50 each or 100 for the 3
All parts located brisbane northside, pickup ok or i can post at your expense
Prefer contact via pm thanks
Mick
Edited by Gts30t
https://www.sau.com.au/forums/topic/421996-r33-gtr-rb26-rb25-and-s15/
Rb25 alternator $50
Mick
have pics of center console? [email protected] thanks
Console is not quite as good as i remember, it has no lid either. Would suit someone who wanted to paint it as i t would come up really nice. Price drop to 50
F1FB3445-5651-42F8-8A9D-EF9439433EC5-302
1E1F012D-28FD-45C6-8920-14EE79649506-302
R33 gtr engine looms and sub looms
EB56E8FC-66BC-4934-9ED7-AA7E63539A92-302
Also have a polished rb20 crossover pipe for sale, $75
R32 gtst air con compressor $100
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
